Need help!!! Regarding zx10r - KawiForums - Kawasaki Motorcycle Forums
post #1 of 5 (permalink) Old 01-06-2017, 02:53 AM Thread Starter
Hi
Actually I'm trying to Get a zx10r to ride this season. I've looked at couple and stumbled upon a 2012 zx10r with 12K miles. But the only thing wrong with the bike is that the key ignition needs to be changed on the bike, which I think it's easy but don't know how to or the parts needed to replace. So if anyone has done an installation on the ignition do let me know how to if it's easy and if it's worth getting that bike.
Thanks
Zx10r6412 is offline
post #2 of 5 (permalink) Old 01-07-2017, 10:07 AM
Originally Posted by Zx10r6412 View Post
Hi
Thanks
Not sure how to fix your problem but I'm assuming you're buying off a private seller and they can't start the bike because of the ignition problem... I'd advise you to ask the seller if you can take the bike to a shop and make sure that that's its only issue because I know a guy who got shitted on like that.... ended up with a sexy but crap bike. It pays off to be sure. Also the shop is probably your best bet on learning how to change the ignition if they are nice and you ask them how or if someone else here is nice enough to respond. Just lookin out ride safe bro.
Sent from my iPad using Tapatalk
Brownj73 is offline
post #3 of 5 (permalink) Old 01-10-2017, 02:10 AM
BlackDog's Avatar
make sure he bike is not stolen and the title is perfect.
The ignition is pretty easy, but there is a secret for anti theft.
you can do keyless if you are heading to the track or replace the ignition if its damaged.
sounds fishy, but can be corrected.
BlackDog is offline
post #4 of 5 (permalink) Old 01-11-2017, 08:15 AM
Startbully
Green's Avatar
This. I'd avoid it completely. No reason for an ignition switch problem on a four year old bike...even if it's been sitting outside the whole time.
Originally Posted by iVintage87 View Post
But cat balls are adorable, have you seen them?! They are like fluffy pompoms right under their butthole.
Originally Posted by Monstermack View Post
well...correct me if I'm wrong...but his wife is Asian...maybe she thinks feeding a dog all this "bad food" is like grass feeding a cow.
Helps with the flavor.
Green is offline
post #5 of 5 (permalink) Old 01-12-2017, 09:49 AM
Great advice!
ZX-10RR is offline
You may post new threads
