turn signal issue on 08 250 - KawiForums - Kawasaki Motorcycle Forums
post #1 of 13 (permalink) Old 06-03-2008, 05:46 PM Thread Starter
hybridsteveo's Avatar
When I push the turn signal to the left the lights don't blink, they just stay solid. The front and back lights do this. Funny thing is that the turn signal light on the dash stays solid as well. When I turn right all the right lights and dash turn signal light blink correctly. Anyone experience this b4?
hybridsteveo is offline
post #2 of 13 (permalink) Old 06-03-2008, 08:40 PM
VeX
I ♥ Cute Cats!
VeX's Avatar
Did you have the left front fairing off and disconnect the wire going to the blinker at all by chance?
VeX is offline
post #3 of 13 (permalink) Old 06-03-2008, 08:53 PM
I just had the same problem today! I noticed my signals werent working at all so i changed the fuse ... now when i use the signals the right one stays solid and the left dosent work at all.... Im gonna take it to my dealer for service this should be warrenty work
alex346 is offline
post #4 of 13 (permalink) Old 06-04-2008, 03:22 AM
shizane101's Avatar
When I crashed my bike and broke off my front right blinker, my left blinker stayed solid when I turned it on. The dash light stayed solid too as you indicated. As soon as I got the blinker and bulb hooked back on the bike things worked just fine.
shizane101 is offline
post #5 of 13 (permalink) Old 06-04-2008, 03:37 AM
Saki Blue Devil
I dropped my bike on the left side and broke my left turn signal. Now when I signal left it stays solid. The right side blinks correctly though.........
jtdubb420 is offline
post #6 of 13 (permalink) Old 06-04-2008, 10:59 AM Thread Starter
I noticed last night that the left front blinker doesn't work. So i'm guessing thats causing the rear to stay solid. Could you tell me the type of bulb you bought? Thanks
post #7 of 13 (permalink) Old 06-04-2008, 02:44 PM
The exact same thing happened to me today. I had the bike in for its first service May 21st. I don't know if that has anything to do with it or if its just a coincidence. I pulled over to the side of the road and turned if off for a minute or two and then it worked again. I have about 2200kms on her. Curious as to how many Km's/Miles you have on yours.
TorbayNinja is offline
post #8 of 13 (permalink) Old 06-04-2008, 03:42 PM
ive got 1800 km's on mine and it happened to me last week
alex346 is offline
post #9 of 13 (permalink) Old 06-05-2008, 06:08 PM
Greetings all. New here and thought I'd add to this. Mine was doing it on the L side as well. Must be a problem from the factory. But anywho; It's not the bulb. It's the female side of the plug. You may have to pull the fairing off to get to the plug; I was able to pull the wires through the top. I just put a slight bend in the male prongs (enough to make good contact) added a dab of electric grease and plugged back together. I haven't had any issued since I did it over a month ago. Hope this works for you too.
Firegod42 is offline
post #10 of 13 (permalink) Old 03-13-2010, 10:28 PM
x2 what firegod did. i fixed my issue with this today the way he did. If this doesn't work you can check your fuses. Of course start with the easiest troubleshooting, first the bulbs!
motoitalia is offline
