Old 07-02-2008, 02:32 PM   #1 (permalink)
UniqueX has at least 10 rep points
Default Upgraded Front and Rear tire to 120/70/17, 150/70/17, Pictures!
Hi everyone,
Well, There's been a lot of requests about comparison pictures for these type of tires and I figured I would take some shots to show you guys just how big of a difference this really is.
The new tires are dunlop sportmax touring D250
130/70/17
150/70/17
110/70/17
120/70/17
I think it looks much better. As far as handling goes, it's still pretty nimble but it's not as flickable as it was with the thinner tires as expected. It feels a lot more stable on curves and freeway riding though. Here are some more pictures just for fun
UniqueX is offline   Reply With Quote
Old 07-02-2008, 02:36 PM   #2 (permalink)
boogahh's Avatar
boogahh has at least 10 rep points
Wow that looks way better! I might just have to upgrade my girlfriends bike! Well at least when the oem ones wear out
boogahh is offline   Reply With Quote
Old 07-02-2008, 02:39 PM   #3 (permalink)
Banned
Ninja_Joe has between 50 and 100 negative rep pointsNinja_Joe has between 50 and 100 negative rep pointsNinja_Joe has between 50 and 100 negative rep pointsNinja_Joe has between 50 and 100 negative rep pointsNinja_Joe has between 50 and 100 negative rep pointsNinja_Joe has between 50 and 100 negative rep pointsNinja_Joe has between 50 and 100 negative rep pointsNinja_Joe has between 50 and 100 negative rep pointsNinja_Joe has between 50 and 100 negative rep pointsNinja_Joe has between 50 and 100 negative rep pointsNinja_Joe has between 50 and 100 negative rep points
Nice post! im diggin the 150 in the rear but not sure if it's a wise upgrade just yet. Seems awfully close to the chain gaurd and slightly taller than the norm, maybe a 150/60/17?.
Ninja_Joe is offline   Reply With Quote
Old 07-02-2008, 02:43 PM   #4 (permalink)
The fitment is really tight. Any higher and you'll be rubbing. I was looking for 150/60/17's but couldn't pass up this deal so decided to try it anyway. I had to adjust the alignment of the rear wheel a bit to make it fit.
As far as the height is concerned, it's barely taller, I noticed also that the speedo is more accurate at higher speeds then before since the wheels are now higher which makes sense with the tire calculator.
Old 07-02-2008, 02:44 PM   #5 (permalink)
I Bleed Green
kkim's Avatar
kkim has between 5,000 and 7,500 rep pointskkim has between 5,000 and 7,500 rep pointskkim has between 5,000 and 7,500 rep pointskkim has between 5,000 and 7,500 rep pointskkim has between 5,000 and 7,500 rep pointskkim has between 5,000 and 7,500 rep pointskkim has between 5,000 and 7,500 rep pointskkim has between 5,000 and 7,500 rep pointskkim has between 5,000 and 7,500 rep pointskkim has between 5,000 and 7,500 rep pointskkim has between 5,000 and 7,500 rep points
curious... what's the weight difference between the old and new tires?
as far as looks... um, looks phat???
kkim is offline   Reply With Quote
Old 07-02-2008, 02:56 PM   #6 (permalink)
ratherberiding
joonyaboy's Avatar
joonyaboy has between 40,000 and 50,000 rep pointsjoonyaboy has between 40,000 and 50,000 rep pointsjoonyaboy has between 40,000 and 50,000 rep pointsjoonyaboy has between 40,000 and 50,000 rep pointsjoonyaboy has between 40,000 and 50,000 rep pointsjoonyaboy has between 40,000 and 50,000 rep pointsjoonyaboy has between 40,000 and 50,000 rep pointsjoonyaboy has between 40,000 and 50,000 rep pointsjoonyaboy has between 40,000 and 50,000 rep pointsjoonyaboy has between 40,000 and 50,000 rep pointsjoonyaboy has between 40,000 and 50,000 rep points
Send a message via Yahoo to joonyaboy
meh
"I always feel a little better after a ride" ~41k miles so far
joonyaboy is offline   Reply With Quote
Old 07-02-2008, 04:59 PM   #7 (permalink)
12013's Avatar
12013 has at least 50 rep points
What exactly did you have to do?
12013 is offline   Reply With Quote
Old 07-02-2008, 05:05 PM   #8 (permalink)
hayes077's Avatar
hayes077 has at least 500 rep pointshayes077 has at least 500 rep pointshayes077 has at least 500 rep pointshayes077 has at least 500 rep pointshayes077 has at least 500 rep pointshayes077 has at least 500 rep points
the problem with lower profile tires is the the lower the height percentage means the wider the tire. Its not supposed to be that way, but it usually is. In theory the 150/60/17 should be the same height as a 130/70/17 and the same width as a 150/70/17, however, you will likely find that the 150/60/17 will most likely be wider than the 150/70/17. It should be quite a bit shorter than the 150/70/17, a bit closer to the same height as the 130/70/17.
anyone confused yet?
Originally Posted by kkim View Post
even if you find the search button that they maded, don't use it, man... it just blows!! Just create another USELESS/REPETETIVE thread to satisfy your lazy ass!!!
hayes077 is offline   Reply With Quote
Old 07-02-2008, 05:11 PM   #9 (permalink)
Banned
i am
Old 07-02-2008, 05:13 PM   #10 (permalink)
hayes077's Avatar
bottom line, a 150/60/17 will probably be a bit wider than the 150/70/17 an will probably hit the chain guard
