seat cowl fitting & gap : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Old 07-02-2008, 10:31 PM   #1 (permalink)
randomwalk101 has at least 500 rep pointsrandomwalk101 has at least 500 rep pointsrandomwalk101 has at least 500 rep pointsrandomwalk101 has at least 500 rep pointsrandomwalk101 has at least 500 rep pointsrandomwalk101 has at least 500 rep pointsrandomwalk101 has at least 500 rep pointsrandomwalk101 has at least 500 rep points
Default seat cowl fitting & gap
finally found a local dealer that has one in stock, black...They wanted 108 but since it back ordered everywhere...I had no choice but to take out the vasaline and took one in the rear.
Installing it, there is a gap on the rear cowl and the seat cowl..quite a large gap..I can stick my finger in 1/2 way...is this normal? On my 600rr, the seat cowl fits perfectly flush..
randomwalk101 is offline   Reply With Quote
Old 07-02-2008, 10:49 PM   #2 (permalink)
errorunknown's Avatar
errorunknown has at least 10 rep points
Did you install the rubber grommet? When mine fell out you could lift up the back. Now that I replaced it, it's pretty flush.
errorunknown is offline   Reply With Quote
Old 07-02-2008, 10:57 PM   #3 (permalink)
Really? When you say flush, you mean there is no gap between the seat cowl meeting the rear cowl (edges)? Yes, all rubber grommet installed.
Old 07-02-2008, 11:05 PM   #4 (permalink)
llenta has at least 1500 rep pointsllenta has at least 1500 rep pointsllenta has at least 1500 rep pointsllenta has at least 1500 rep pointsllenta has at least 1500 rep pointsllenta has at least 1500 rep pointsllenta has at least 1500 rep pointsllenta has at least 1500 rep pointsllenta has at least 1500 rep pointsllenta has at least 1500 rep pointsllenta has at least 1500 rep points
my seat cowl sits flush with the rear fairings. you shouldn't be able to get your fingers in there at all.
llenta is offline   Reply With Quote
Old 07-02-2008, 11:24 PM   #5 (permalink)
here are a couple of pics..can someone confirm? I might need to return this one??
Old 07-02-2008, 11:31 PM   #6 (permalink)
trusol has at least 250 rep pointstrusol has at least 250 rep pointstrusol has at least 250 rep pointstrusol has at least 250 rep points
mine never came with a rubber grommet to fill in that gap and i got the kawasaki box too and it doesnt say its included but see your post doesnt say anything about the solo cowl so we thought you had ment the seat
but yeah theres a gap in mine also, i could bend it but it works just fine.
trusol is offline   Reply With Quote
Old 07-02-2008, 11:36 PM   #7 (permalink)
Well there are four rubber feet as you see in the pic of the seat cowl openned up....the rubber grommet he's talking about is probably the one installed in the bike where the pin at the end of the seat cowl slides into...(not in pic).
So there *IS* a gap going around under the seat cowl like that right???
Old 07-03-2008, 12:53 AM   #8 (permalink)
bushidokawi's Avatar
bushidokawi has at least 1500 rep pointsbushidokawi has at least 1500 rep pointsbushidokawi has at least 1500 rep pointsbushidokawi has at least 1500 rep pointsbushidokawi has at least 1500 rep pointsbushidokawi has at least 1500 rep pointsbushidokawi has at least 1500 rep pointsbushidokawi has at least 1500 rep pointsbushidokawi has at least 1500 rep pointsbushidokawi has at least 1500 rep pointsbushidokawi has at least 1500 rep points
I have a gap on mine as well, but only on the left side. The right side is flat and flush, but tge left side has just like you said, about a 1/2 inch gap between the solo cowl cover and the rear fender cowl.
Mods: Two brothers exhaust, Dynojet jet kit, shimmed needles, DYI fender eliminator, DIY tinted windscreen, 4000K bulbs, Shogun Swingarm spools, CF tank protector, reflective wheel tape
bushidokawi is offline   Reply With Quote
Old 07-03-2008, 12:56 AM   #9 (permalink)
SolaFidae's Avatar
SolaFidae has at least 50 rep pointsSolaFidae has at least 50 rep points
i have the black cowl also on my bike and there IS a gap BUT!!!! i installed some LED pods under there and it looks pretty sick with a slight glow coming out of it at night....
probably doesnt help much but just thought id chime in
SolaFidae, SolaChristo, Sola Gratia....=Faith alone, in christ alone, through grace alone...
SolaFidae is offline   Reply With Quote
Old 07-03-2008, 03:55 AM   #10 (permalink)
switchlanez's Avatar
switchlanez has at least 10 rep points
I bought a secondhand black cowl and I didn't notice any significant gap. Is yours clamped down all the way so it locks? I heard it takes a while for the rubber stoppers to settle in. There will be improvement after long term fitment, like this guy said:
http://www.2fiddy.com/2008/05/kawasa...owl-follow-up/
Seems Kawasaki contracted this part out from some cheap vendor. The factory seat is made with better materials, a better lock mechanism, and enough labels/markings making the Kawasaki branding seem very genuine
Poseable action figure not included.
switchlanez is offline   Reply With Quote
