Bogging upon throttle up. - KawiForums - Kawasaki Motorcycle Forums
post #1 of 7 (permalink) Old 10-30-2009, 08:55 AM Thread Starter
Jarsh's Avatar
Send a message via Yahoo to Jarsh
I'm sure there are other threads about this but the search function seems to be borked. So if there is a thread with a solution to this don't hesitate to post it and say "look here n00b".
I live in Houston, TX where the weather is usually decent for riding year-round. Yesterday I was riding home and got caught in a major rain storm. As I got home the bike seemed to not want to throttle up and seemed to bog down when I opened the throttle. So I let it sit indoors overnight and when I went to warm it up this morning it warmed up and idled fine. But again, when I tried to open up the throttle one bit it bogged down. If I let the throttle go back to closed it would idle properly. When I put the choke full-on it would rev up to 6-7k which seems normal. I'm thinking maybe during the rain storm I might have gotten water in the intake. That's the only thing I could think of that would warrant such behavior.
If this is the problem what steps would I have to take to get this thing operating properly again?
Thanks for your help.
-Jarsh
EDIT: To update, I've pulled the air filter and started it with the air filter removed, still idles fine bogs above idle. I also opened up the gas tank and ran it, same results.
Jarsh is offline
post #2 of 7 (permalink) Old 10-30-2009, 10:57 AM Thread Starter
Jarsh's Avatar
Warmed it up again for 20 minutes. Tested the throttle. Engine rev's up to 4k for about 1 second then the engine bogs. After waiting for the engine to return to normal idle speed and turning the throttle again it goes back up to 4k for about a second. I did this a few times to see if conditions improved but it stayed consistent. Full-choke still yeilds a 6-7k rpm under no load.
Please advise.
Jarsh
Jarsh is offline
post #3 of 7 (permalink) Old 10-30-2009, 03:02 PM
drain all the gas from your tank and refill with fresh gas. Also, drain your carb bowls. Sounds like you might have gotten water in the gas and it's sitting in the bowls.
what year is your bike and have you been riding it consistently prior to this happening?
kkim is offline
post #4 of 7 (permalink) Old 10-31-2009, 05:57 AM
CZroe's Avatar
Mine does this until it's fully warm. Are you sure that's not it?
Even a lengthy warm-up doesn't do it sometimes (cool weather)... I just gotta get out and ride it. Be careful because if you open the throttle and feather the clutch to keep the engine from dying it will continue to bog for a few moments and then suddenly ramp the RPMs sky-high.
Just moved to SoCal from the Atlanta region (Newnan, GA)... Yes, I rode my 250.
CZroe is offline
post #5 of 7 (permalink) Old 11-02-2009, 10:30 AM Thread Starter
Jarsh's Avatar
Fixed the bike. Thanks KKim, draining the carbs did the trick. I appreciate the quick response guys.
Jarsh is offline
post #6 of 7 (permalink) Old 11-02-2009, 10:47 AM
shadows090's Avatar
Send a message via AIM to shadows090
weird. I would think spark. It may not be a bad idea to double check the plugs also. Even though its fixed
The national budget must be balanced; the arrogance of the authorities must be moderated and controlled... If the nation doesn't want to go bankrupt, people must again learn to work, instead of living on public assistance. Marcus Tullius Cicero, 55 BC
Dependence leads to subservience. Jefferson
shadows090 is offline
post #7 of 7 (permalink) Old 10-26-2010, 01:05 PM
Jaiyla's Avatar
Bike dying with choke and gas...
Okay. I have a wonderful problem and have parted ways with the (now ex) boyfriend that knew what to do in these situations.
I got my bike into the garage storage I wanted it in, but it's running terribly. It has only a little over 200 miles on it (it was a terrible summer), brand new 2008 250. I run it probably once every two weeks, maybe not enough? But recently it's been giving me problems. I'll have it running with full choke, let it warm up for over ten minutes, and when I give it gas, it still dies. It sounds like it's really not getting enough gas, but I do have gas in there.
I feel like a really dumb girl right now, but I do want to get this thing running correctly so I can figure out how I'm going to winterize it. You live and learn, right!? Any help would be great. Unfortunately for me, I don't know a lot about bikes mechanically.
*Two Brothers Carbon Fiber Slip-On*Targa No-Cut Fender Eliminator*Roaring Toyz Lowering Links*
Jaiyla is offline
