ZX6R rear shock *sorta* howto - Page 3 : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Old 12-12-2012, 12:08 PM   #21 (permalink)
fixxervi6 has at least 10 rep points
I hope you're going to get a lighter spring.
Why?
fixxervi6 is offline   Reply With Quote
Old 12-12-2012, 12:11 PM   #22 (permalink)
TJ Beavers
goingtoscotland's Avatar
Because the 250 weighs almost 50lbs less than a J model
Old 12-12-2012, 02:59 PM   #23 (permalink)
I weigh 227lbs naked, I don't think they had that kind of weight in mind when they built these, I assume the stock spring would be enough. I'm a little heavy for the stock spring on my GSXR's.
Old 12-13-2012, 01:15 PM   #24 (permalink)
ninjaryda has at least 10 rep points
I just picked up my first bike; 2007 250r. The first thing I noticed was how bouncy the back end of the bike is, and I'm fairly light (~150lbs dressed). I saw this modification and the first thing that I noticed, and liked, was that it raised the rear up a bit. I love that look (I like the more aggressive look). I read the link that describes the rake/tree and all of that and my question is this: does raising the bike/rear 2 inches like this drastically change the handling of the bike? If so, what are the negative side effects?
-Tom
ninjaryda is offline   Reply With Quote
Old 12-13-2012, 03:24 PM   #25 (permalink)
depends on how hard you push the bike
<-- not an expert
but my understanding that nose down = easy tip in but less stable mid corner, which can lead to other handling issues.
I plan on putting lowering links on to get the bike back close to stock height.
Old 12-22-2012, 05:42 PM   #26 (permalink)
Went to lower the bike back down to stock height using some Soupy's lowering links and ran into a problem, the links hit the spring.
Pushed the old bushings out of the stock links, then ground them down to create giant spacers with a washer behind it. This is a "test" checking clearance, I continued to grind after this until the link was parallel.
