How many miles does a EX250 last? : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Old 06-26-2012, 12:15 PM   #1 (permalink)
mvmacd's Avatar
mvmacd has at least 10 rep points
Default How many miles does a EX250 last?
I'm just wondering how many miles you can realistically expect to get on a EX250.
I bought a 2002 EX250 with 13,xxx miles a week ago, and I'm wondering how many miles I could expect from it. It was sitting for 2 years due to a lost key & stator problems, and was salvaged 2 owners ago, it has a reconstructed title.
I'm going to change the oil & put in a new oil filter while I'm replacing the stator, is there anything else I should do to ensure a long engine life?
mvmacd is offline   Reply With Quote
Old 06-26-2012, 12:22 PM   #2 (permalink)
brenthedtke83 has at least 10 rep points
Be good about your riding habits, basically. Baby the clutch, don't throttle any harder than you have to, etc. Just baby it.
Depending on the dealer and/or mechanic that you talk to, there's a lot of debate about how may miles you can expect from your bike. 13k is just barely broken in, but local mechanics that I've talked to said you can get anywhere from 50k-75k out of it if you do it right. Just do regular maintenance like you should, and take good care of it.
brenthedtke83 is offline   Reply With Quote
Old 06-26-2012, 02:37 PM   #3 (permalink)
G-shoe has at least 10 rep points
Saw a 08 last weekend with 26000km's on it, and still going strong.
Thats pretty amazing for such a small engine running at high rpm's
G-shoe is offline   Reply With Quote
Old 06-26-2012, 02:57 PM   #4 (permalink)
Ninja650r2009's Avatar
Ninja650r2009 has between 7,500 and 10,000 rep pointsNinja650r2009 has between 7,500 and 10,000 rep pointsNinja650r2009 has between 7,500 and 10,000 rep pointsNinja650r2009 has between 7,500 and 10,000 rep pointsNinja650r2009 has between 7,500 and 10,000 rep pointsNinja650r2009 has between 7,500 and 10,000 rep pointsNinja650r2009 has between 7,500 and 10,000 rep pointsNinja650r2009 has between 7,500 and 10,000 rep pointsNinja650r2009 has between 7,500 and 10,000 rep pointsNinja650r2009 has between 7,500 and 10,000 rep pointsNinja650r2009 has between 7,500 and 10,000 rep points
fourteen
I'm an A* you should already know this; I ride a sport bike.
Ninja650r2009 is offline   Reply With Quote
Old 06-26-2012, 03:03 PM   #5 (permalink)
mvmacd's Avatar
Edit:
Okay, I'll go through the stickies on the n00b section and hopefully pick up some useful tips.
So how about oil, how often should I change it? I live in Massachusetts, and let my bike sit through the winter [down to zero, sometimes colder], under a motorcycle. I should clean out a space in my garage :P but it's packed full with stuff.
I am considering Rotella T6, as it was recommended on faq.ninja250.org. Any thoughts on that?
And if I only put 1K or less mi a year, should I change the oil every 2 years? or every year
Old 06-26-2012, 03:07 PM   #6 (permalink)
Powerhungry
nevada's Avatar
theres no need to baby it.
obviously dont ABUSE IT, but use it how you would. it will be fine.
it will likely outlast the rider. OR it will be wrecked first.
Old 06-26-2012, 03:08 PM   #7 (permalink)
40SYM's Avatar
40SYM has between 5,000 and 7,500 rep points40SYM has between 5,000 and 7,500 rep points40SYM has between 5,000 and 7,500 rep points40SYM has between 5,000 and 7,500 rep points40SYM has between 5,000 and 7,500 rep points40SYM has between 5,000 and 7,500 rep points40SYM has between 5,000 and 7,500 rep points40SYM has between 5,000 and 7,500 rep points40SYM has between 5,000 and 7,500 rep points40SYM has between 5,000 and 7,500 rep points40SYM has between 5,000 and 7,500 rep points
I love the 250r section...
Sent from my SCH-I510 using Motorcycle.com Free App
40SYM is offline   Reply With Quote
Old 06-26-2012, 05:32 PM   #8 (permalink)
srt4evah's Avatar
srt4evah has at least 250 rep pointssrt4evah has at least 250 rep pointssrt4evah has at least 250 rep pointssrt4evah has at least 250 rep points
Correct Answer: Eleventy Gazillion
2012 Ninja ZX6R
2011 Ninja 250R
srt4evah is offline   Reply With Quote
Old 06-26-2012, 06:22 PM   #9 (permalink)
WantToGetANinja's Avatar
WantToGetANinja has at least 2000 rep pointsWantToGetANinja has at least 2000 rep pointsWantToGetANinja has at least 2000 rep pointsWantToGetANinja has at least 2000 rep pointsWantToGetANinja has at least 2000 rep pointsWantToGetANinja has at least 2000 rep pointsWantToGetANinja has at least 2000 rep pointsWantToGetANinja has at least 2000 rep pointsWantToGetANinja has at least 2000 rep pointsWantToGetANinja has at least 2000 rep pointsWantToGetANinja has at least 2000 rep points
This isn't true. You don't need to baby the bike at all. If anything, the 250 can take much abuse without faltering. I'm not saying you should practice clutch up wheelies all day, etc, but you can go WOT all the time, nothing is going to happen. Keep up with the maintenance, that's the only key. Miles mean nothing if the bike is well maintained (this goes for cars and everything else as well). Miles usually scare people away because they figure it's been driven a lot and will have problems, but that's pretty silly to think. Especially for the 250R's, if they sit, they generate a lot more issues than those which are driven often.
WantToGetANinja is offline   Reply With Quote
Old 06-26-2012, 11:11 PM   #10 (permalink)
srt4evah's Avatar
^^ yah so many posts about people who found a 250 that sat for 6 months or a year or two, and won't run. Nobody complaining about one that had issues after 10k, 30k, 50k miles etc.
2012 Ninja ZX6R
2011 Ninja 250R
