The rear one works perfectly fine for my 08. it has interchangeable mounts, i dont have rear spools so i use the little rubber blocks under the swing arm. Idk how the 07's are but if the swing arm is even and flat on the underside of it then it should work fine. if you have spools you can flip the mount around. Good stand overall though for the price cant beat it.
