Stripped Carburetor Bolt : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Old 11-04-2012, 05:04 PM   #1 (permalink)
KentuckyKawi's Avatar
KentuckyKawi has at least 250 rep pointsKentuckyKawi has at least 250 rep pointsKentuckyKawi has at least 250 rep pointsKentuckyKawi has at least 250 rep pointsKentuckyKawi has at least 250 rep points
Default Stripped Carburetor Bolt
Hey guys. i was hoping that you all might have some tips to remove a bolt that i am having trouble with. i was in the process removing the top part of the right carb so that i could get to the needles and add a washer underneath. my 250 is running really lean so i needed to get into there. anyways, i got 3 screws out and the final one on the front right of the carb stripped. (on the right carb) any tricks to remove this bolt???
Yes We Have Shoes In Kentucky... We Also Have Motorcycles.
-KentuckyKawi
KentuckyKawi is offline   Reply With Quote
Old 11-04-2012, 05:09 PM   #2 (permalink)
ZX6R>CBR's Avatar
1) Grab a pair of vise grips and go at it
or
2) go to home depot/lowes and buy the grabit bit.
Did you add an aftermarket air filter or anything else to make it run lean?
ZX6R>CBR is offline   Reply With Quote
Old 11-04-2012, 06:24 PM   #3 (permalink)
i did the snorkel mod. relatively simple fix should i not be able to get this screw out. but i enjoy the snorkel out.
-KentuckyKawi
Old 11-04-2012, 06:47 PM   #4 (permalink)
Sev
The Indifference Engine
Sev's Avatar
Vice grips or drill the head off the bolt and then vice grips.
Old 11-04-2012, 09:19 PM   #5 (permalink)
2002ZX-6R has at least 1500 rep points2002ZX-6R has at least 1500 rep points2002ZX-6R has at least 1500 rep points2002ZX-6R has at least 1500 rep points2002ZX-6R has at least 1500 rep points2002ZX-6R has at least 1500 rep points2002ZX-6R has at least 1500 rep points2002ZX-6R has at least 1500 rep points2002ZX-6R has at least 1500 rep points2002ZX-6R has at least 1500 rep points2002ZX-6R has at least 1500 rep points
I'm no expert but I have heard people suggest using a hacksaw or dremell to put a slot on the head and try a LARGE flathead screwdriver.
2002ZX-6R is offline   Reply With Quote
Old 11-06-2012, 07:24 PM   #6 (permalink)
Great! the vice grips did the trick! however, i cannot find any washers to put under the needle to lift it!!!!! does anyone have some i could purchase?
-KentuckyKawi
Old 11-06-2012, 07:27 PM   #7 (permalink)
Also to add more info: after removing the snorkel i get a serious sputter between 5-7000 rpm and it almost stalled me in the middle of a highway the other day killing myself and my girlfriend. it was pretty serious. that is why i need to get this fixed.
-KentuckyKawi
Old 11-08-2012, 07:47 AM   #8 (permalink)
Actonite has at least 10 rep points
Just go buy a jet kit, it comes with everything you need to get it running right.Dynojet Jet Kits - Offering Motorcycle Jet Kits & ATV Jet Kits
Actonite is offline   Reply With Quote
