Anyone had to helicoil the oil drain plug? : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Old 11-24-2012, 06:11 PM   #1 (permalink)
exalted512's Avatar
Default Anyone had to helicoil the oil drain plug?
Picked up a used 250. Among the problems I've found so far is the dumbasses stripped the drain plug.
Is there a how to somewhere on fixing this? Or does anyone know what size helicoil tap I need to use to keep the stock drain plug bolt?
Thanks!
-Cody
2009 650R (Street)--Stock
exalted512 is online now   Reply With Quote
Old 11-24-2012, 08:04 PM   #2 (permalink)
Sev
The Indifference Engine
Sev's Avatar
Used sump Aprox $100
Heli coil kit. Almost the same price.
Old 11-24-2012, 11:40 PM   #3 (permalink)
exalted512's Avatar
the more and more research I've done...it seems a time-sert or just a bigger self tapping drain plug bolt is the way to go. I'd really like to do it right...which I think the time-sert is the right way...but I also am at the point where I want it done and done with little money...so the drain plug is looking more and more attractive.
-Cody
Old 11-25-2012, 12:23 AM   #4 (permalink)
whitehendrix's Avatar
i personally think a time-sert is better than a heli coil simply because you can seal the outer threads and it'll NEVER leak. a heli-coil can shift a bit and work around, and expands at a different rate than the aluminum it's in. i can't be sure if its a 12 or 14mm thread, but its something like that. common noob bullshit on those bikes. or, if you want it under $60, mail it to me, i'll weld the hole up, and either drill and tap or you can. just slip me like 20 or 30 in the box for my welding time (which is a discounted rate since i love ya.. otherwise it'd be $45) and cover shipping and i'll be sure to build the boss up another .100 at least so theres some meat there for the bolt.
►Sept09 B.O.T.M. winner◄
Need A "How To"? CLICK ME!!
Old 11-25-2012, 02:32 AM   #5 (permalink)
I would fight Abe Lincoln
RacinJason44's Avatar
My old dirt bike had a fucked up drain bung at some point and someone before me rewelded a new one one. Always an option.
OMRRA Novice # 744
Old 11-25-2012, 10:05 AM   #6 (permalink)
Lowsiding Extraordinare
Ninjabadger4's Avatar
+1, you want to remove the pan anyway so you dont get shaving inside your sump
You're killing two stone with one bird
Old 11-25-2012, 10:15 AM   #7 (permalink)
exalted512's Avatar
There's no oil pan on these bikes I'd have to mail you the whole lower half of the engine...haha
What are your thoughts on just saying fuck it and using a self tapping drain plug?
-Cody
Old 11-25-2012, 10:35 AM   #8 (permalink)
-Cody
You are overthinking it, an oil pan on a 6r looks like a part of the lower engine but isnt
Old 11-25-2012, 10:37 AM   #9 (permalink)
Thanks!
-Cody
My model year did you get? If you got a 2008+, just replace the oil cover. It's cheap cast metal and may not even work with helicoils or time-serts
14091-1575 Kawasaki COVER,1ST FILTER $32.89
Old 11-26-2012, 12:17 AM   #10 (permalink)
cody, if the shits not cracked and you wanna just time-sert it, you can drill slowly enough to keep the chips out, and when you thread it, coat the tap in grease. i've rethreaded spark plug holes before and thats what i did.. obviously, heads still on the vehicle..
any chips can be scooped out with a little piece of wire dipped in grease or sprayed out with the bike tipped over a bit and some carb cleaner. make sure not to get that shit in your eyes!
