I like an oil mix to make my own semisynthetic, but many people would get a blowjob from their grandmother before they mixed oils.
A couple of quotes that I found-
"The oil that works well for others might not work well for you, even in the same make/model bike. Amsoil made my bike jump out of 5th and was a bear to find neutral, but other people run it without issue."
"The ZX-14 has a lot of HP and torque and it loves the Rotella T. The ZX-14s run hot normally and the Rotella T has helped the bike run much cooler too. I highly recommend Shell Rotella T synthetic [T5 or T6]."
"That's great advice.....go to a Suzuki Katana forum to get info about a Kawasaki
......just fucking brilliant."
The answer I would expect from someone with nothing new to add, just bashing.
I've used the T5 and T6 for the last couple years, nothing bad has happened, everything feels the same, bikes run just fine. Done trackdays, everything went well and still is. I have it in my 250, Daytona 675, and my little CRF70, all run just fine. A company like Shell isn't going to put an oil out with a JASO MA certification that is going to murder your bike.
Originally Posted by FightingFalcon
All I'm saying is that our trannys are designed to handle the load (yea, I just said that)
0protection just as good as mc oil...higher levels of protective additives...more affordable...plus it has the required spec as well as JASO...and no warranty issues.
I've used Rotella T6 5W40 in a 250, as well as my 650. No issues with either. I have a diesel car and this oil is suitable for both car and bike, so I only have to keep one kind on hand.
2007 Ninja 650R-Scorpion slip-on, formerly lowered, still cosmetically challenged.
2006 Ninja 250R-Totalled by an inattentive Toyota driver while parked.
