Kawasaki ninja ex250 no spark still. - KawiForums - Kawasaki Motorcycle Forums
post #1 of 4 (permalink) Old 02-04-2017, 08:59 PM Thread Starter
Howdy yall. So I have a 2005 ex250 with a no spark issue. So here's what I've done.
New stator,starter,cdi,spark plugs, relay, battery
Tested good:ignition coils
Cleaned: carbs
Maintain: oil change.
Symptoms: won't start at all. When o pull the spark plugs out and test if they spark they dont. Any help would be wonderful I'm been trying to fix my bike for 4 months now
Kitamuro is offline
post #2 of 4 (permalink) Old 02-05-2017, 09:24 AM
Ebny250's Avatar
Cleaned: carbs
Swap ur ignition there is a resistor in the ignition and if it burns you get all but actual starting! You could make a test jumper with 110ohm 1/4watt resistor but you gotta be ok with wiring and it's a bit of a bear...
Sent from my iPhone using Tapatalk
Originally Posted by bubbleboys
*sigh* you and your constant "anything below 600 isn't a real bike" rhetoric
Ebny250 is offline
post #3 of 4 (permalink) Old 02-05-2017, 03:36 PM Thread Starter
Ill try thay. But would the ignition cause the spark plugs not spark
Kitamuro is offline
post #4 of 4 (permalink) Old 02-13-2017, 11:31 AM
Ebny250's Avatar
Yes
Ebny250 is offline
