Throttle Cable - KawiForums - Kawasaki Motorcycle Forums
post #1 of 2 (permalink) Old 04-05-2017, 11:24 AM Thread Starter
Throttle Cable
Hello, while working on the carbs for my 2006 ninja 250 i messed with the throttle cables because ever since I had the bike, if I turned to the right, it would accelerate. Now everything is out of whack. It accelerates too high and the throttle won't return. Is there so factory default setting for this? Any help is appreciated.
Sent from my LG-H901 using Tapatalk
Erics9971 is offline
post #2 of 2 (permalink) Old 04-20-2017, 11:14 PM
Sounds like the decelerator cable isn't installed properly. I'd wager that it's either too loose or perhaps not attached.
I'd make sure it's attached and that it's roughly as tight as the accelerator cable.
I suppose it could need some lubrication.
pfranks is offline
