Clutch Pedal? - Page 2 : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Go Back   KawiForums - Kawasaki Motorcycle Forums > On-Road > Ninja 500R
Old 12-13-2012, 10:17 AM   #11 (permalink)
Powerhungry
nevada's Avatar
the shifter may need adjusted up, so you can slide your toe under it easily.
just make sure its not too high, or you wont get it fully into gear. and getting the 1-2 shift is harder, since it has t go through neutral.
Old 12-13-2012, 10:29 AM   #12 (permalink)
fshane22's Avatar
fshane22 is around zero rep points
i wear a size 11 shoe... neveda that's exactly my issue. i can't seem to get my toe under to shift
fshane22 is offline   Reply With Quote
Old 12-13-2012, 10:37 AM   #13 (permalink)
mpusch has at least 50 rep pointsmpusch has at least 50 rep points
I wear a size 12, never had that problem FWIW.
mpusch is offline   Reply With Quote
Old 12-13-2012, 10:43 AM   #14 (permalink)
fshane22's Avatar
"the more i ride, the more comfortable i will get with it"
That's what i'm taking from this post
Old 12-13-2012, 11:05 AM   #15 (permalink)
cookiebug79's Avatar
This picture is upside down, but you should be able to turn the screws and adjust the height of the pedal. The screw that goes to the transmission is reverse threaded.
Old 12-13-2012, 11:08 AM   #16 (permalink)
fused2explode's Avatar
fused2explode has at least 10 rep points
I wear a 16, takes a little legwork to change between shifting up and down but I don't have a problem getting under it. You can probably adjust it as mentioned
fused2explode is offline   Reply With Quote
Old 01-04-2013, 08:40 PM   #17 (permalink)
whitehendrix's Avatar
what cookie said. move the yoke on the splines or twist the turnbuckle and lock the 10mm nuts back down. 2 options for adjustment.
►Sept09 B.O.T.M. winner◄
Need A "How To"? CLICK ME!!
Old 01-04-2013, 10:37 PM   #18 (permalink)
NgoBoy's Avatar
NgoBoy has at least 250 rep pointsNgoBoy has at least 250 rep pointsNgoBoy has at least 250 rep points
Brotha, if it doesn't look like this, you don't need to buy a new shifter, you need to fix your foot positioning.
NgoBoy is offline   Reply With Quote
Old 01-23-2013, 11:18 AM   #19 (permalink)
fshane22's Avatar
my local shop adjusted it up and now my foot slides right under. thanks for the suggestions everyone!
Old 01-23-2013, 04:00 PM   #20 (permalink)
NgoBoy's Avatar
Glad we could help
