Old 12-12-2009, 03:59 PM   #1 (permalink)
thedru13 has at least 250 rep pointsthedru13 has at least 250 rep pointsthedru13 has at least 250 rep pointsthedru13 has at least 250 rep pointsthedru13 has at least 250 rep points
Default 650r Smells like Coolant
I just picked up a 2006 650r. It was freezing so did not ride it. I got it home and left it running for a few minutes and I smell coolant. Is that normal? I smell it around the radiator. Not really coming from the exhaust. I am going to do a flush. Please tell me I didn't just buy a bike with a blown head gasket. Anything I should look at? They guy said it ran fine and no issues. I did notice some oil around the drain plug but think that is a bad crush washer. I am going to change the oil right away and check to see if I see any coolant in mixed in there. I could slap myself right now.. Any other suggestions would be great. Is there a trick to draining the coolant? Thanks.
thedru13 is offline   Reply With Quote
Old 12-15-2009, 02:49 PM   #2 (permalink)
DoomXexec311's Avatar
DoomXexec311 has at least 500 rep pointsDoomXexec311 has at least 500 rep pointsDoomXexec311 has at least 500 rep pointsDoomXexec311 has at least 500 rep pointsDoomXexec311 has at least 500 rep pointsDoomXexec311 has at least 500 rep points
Hey, may want to check that your coolant is not over flowing in the reserve. Also check the water pump gasket.
Kawasaki Ninja 650 Motorcycles
got to this site it has the links to some common and rare occurrences to the 650r.
That website also has the service manual pdf and tons of other information to the 650r. Read through it all.
Good Luck!
DoomXexec311 is offline   Reply With Quote
Old 12-24-2009, 06:37 AM   #3 (permalink)
jnhuscg has at least 50 rep pointsjnhuscg has at least 50 rep pointsjnhuscg has at least 50 rep points
I've noticed that mine kinda smells like coolant too, but they told me at the shop its going to smell funny for a while because its brand new
jnhuscg is offline   Reply With Quote
Old 12-24-2009, 08:31 AM   #4 (permalink)
08_650r has at least 500 rep points08_650r has at least 500 rep points08_650r has at least 500 rep points08_650r has at least 500 rep points08_650r has at least 500 rep points08_650r has at least 500 rep points
Mine used to do that to, take a nut driver and check all of your lines...
08_650r is offline   Reply With Quote
Old 12-24-2009, 08:57 AM   #5 (permalink)
I did find a coolant leak coming from teh water pump. I am going to repalce the seals but I have also read that the radiator cap may be bad so going to replace that to and see if the smell goes away.
