'09 ER-6n Woodcraft frameslider install problem - KawiForums - Kawasaki Motorcycle Forums
post #1 of 7 (permalink) Old 04-29-2011, 06:43 PM Thread Starter
mudhudhudhu's Avatar
Angry '09 ER-6n Woodcraft frameslider install problem
Has anyone managed to successfully install the left side of the Woodcraft frame sliders on an 09 ER-6n? Can you share how you did it.
The left side came with an 8mm bolt and washer, but according to the spot to install it has a two welded bits around it, which narrow the diameter so the slider base doesn't fit.
Any help is appreciated.
mudhudhudhu is offline
post #2 of 7 (permalink) Old 05-01-2011, 08:20 PM Thread Starter
Anyone? Bueller? Bueller?
post #3 of 7 (permalink) Old 05-03-2011, 03:21 PM
TonyBKK's Avatar
2006 GSXR 1000 aka "The BEAST"
2009 Kawasaki ER6n "RR"
2010 Lime Green Ninja 650R!- SOLD :-(
2011 Versys has arrived!
20xx KLX Bill Blue 351 ^_^v
TonyBKK is offline
post #4 of 7 (permalink) Old 05-03-2011, 09:32 PM Thread Starter
Originally Posted by TonyBKK View Post
I had the wrong placement before (the bolt just behind the frame junction. The right place is the spot in the pics at the link below where the two parts of the frame meet, with the huge circular hole and bolt in the middle. I realise I will need to cut the shroud if I use the woodcrafts or get the ones shown in the same link.
AsianConnection71 items - Get great deals on Kawasaki ER6n Install Instructions items on eBay Stores!
post #5 of 7 (permalink) Old 05-06-2011, 02:36 PM
Filip_ER6F's Avatar
Send a message via Skype™ to Filip_ER6F
Any instructions on how to properly install the Woodcraft Frame Sliders on a 09 would be greatly appreciated - am about to do the install on sunday.
Didn't know there would be any problems (apart from frame cutting which is a PITA).
Filip_ER6F is offline
post #6 of 7 (permalink) Old 05-06-2011, 03:25 PM
The frame sliders are 2" in diameter but use a 2 1/4" hole saw or you will spend 30minutes dremmeling your fairings if you aren't exactly precise (my lesson learned). Also, make sure you lay your fairing on a blanket or something else soft while you are working. I had mine on a cardboard box which I thought was fine but when I pulled it back up it had a huge streak of tiny scratches in the clearcoat from where it was rubbing on the cardboard. Maybe I'm just retarded and these tips are obvious but I thought I'd share them anyway lest you repeat my mistakes.
burfster is offline
post #7 of 7 (permalink) Old 05-07-2011, 11:33 AM
Filip_ER6F's Avatar
I appreciate alle the help, brother.
I think it's better to listen to something twice than misheard it once.
Do you have any pictures of your install? They would help a lot for sure cause I have never installed sliders on a faired bike before..
Cheers
