YSS Shock Absorber - Page 3 - KawiForums - Kawasaki Motorcycle Forums
post #21 of 41 (permalink) Old 06-13-2011, 10:14 AM
TonyBKK's Avatar
I'm running a YSS MZ506-295TRL-13 on my ER6n:
2006 GSXR 1000 aka "The BEAST"
2009 Kawasaki ER6n "RR"
2010 Lime Green Ninja 650R!- SOLD :-(
2011 Versys has arrived!
20xx KLX Bill Blue 351 ^_^v
TonyBKK is offline
post #22 of 41 (permalink) Old 06-14-2011, 01:26 PM
Originally Posted by TonyBKK View Post
Retail price here in Thailand is about 12,000 Thai Baht or roughly US$400
Are there any YSS distributors in the US?
Progressive spring, stepless pre-load and rebound damping make it a hell of a lot better than stock.
In this pic height adjustable YSS Versys shock on the left and YSS EX650 shock on the right:
will using the versys YSS shock (black one) on an ER6F 2010 ABS have any negative effects on the bike? My reading suggests that the height of my bike will increase....
cheers
NinjaXP is offline
post #23 of 41 (permalink) Old 06-15-2011, 02:34 PM
TonyBKK's Avatar
cheers
The Versys shock is height adjustable so you can decide if you want to raise or lower the rear of your bike. I switched from the ER6n shock to the Versys shock because I wanted to raise the rear of my ER6n.
Ride On!
T
TonyBKK is offline
post #24 of 41 (permalink) Old 06-16-2011, 05:51 PM
Thank you Tony
NinjaXP is offline
post #25 of 41 (permalink) Old 08-03-2012, 10:13 AM
jay-j@y's Avatar
can you give more details/feedback on your YSS shocks? someone told me that the YSS doesn't last that long. i'm also eyeing this rear suspension as a replacement to the OEM.
"From the far east I will bring your offspring..."
jay-j@y is offline
post #26 of 41 (permalink) Old 08-04-2012, 10:12 PM
06ninja650r's Avatar
Does anyone know if this is a solid upgrade for the 2006 ninja 650r's stock one for riding 2 up? I plan on mostly riding solo but I want to be able to ride 2 up without worrying about it bottoming out. Since it's a progressive shock its seems promising but I don't know much about it so any information on this would be greatly appreciated! Thanks
06ninja650r is offline
post #27 of 41 (permalink) Old 08-06-2012, 10:01 AM
I'm assuming that this shock also applies to the '12 ninjas as well? Would this shock be a good choice over some of the other suspension upgrades. BUT idk if there are any YSS sellers over here.
Rusted_Relic is offline
post #28 of 41 (permalink) Old 08-06-2012, 02:57 PM
What is keeping the middle of the bike up when you remove the shock? Don't you have to put a jack under the oilpan or something? I imagine the bike buckling w/o the rear shcok on, even with jackstands
Honda Grom headlight Morimoto D2S bixenon projector DDM Tuning 55W HID kit Yoshimura TRC exhaust Renthal Superbike Low Bars Corbin seat ZX9R cluster (no speedo healer!)
My bike is REALLY confused
sportyaccordy is offline
post #29 of 41 (permalink) Old 09-05-2013, 11:37 PM
YSS installed on 2010 650R
This thread is over a year old, but I just installed the YSS shock in a 2010 650R. I bought the adjustable model (MZ506-285TRL-09) because that seems to be the one that is readily available in Bangkok. It can be adjusted in the range of 280-290mm, so it's at the extreme end of its adjustment range to match the stock 290mm shock length. The non-adjustable version is part # MZ506-290TR-09. Both come with a 180 newton-meter spring (red and black colors are available).
The 24mm locking nut on the length adjuster is on extremely tight from the factory. You need a beefy 24mm open-ended wrench to loosen the nut along with a 22mm wrench across the flats of the upper shock body to prevent the shock from rolling while you loosen/re-tighten the nut.
I supported the bike with a pair of jack stands under the foot pegs (very steady!). You'll also need to lightly support the rear wheel, so that it won't abruptly drop to the ground when you remove the shock bolts. The bolts need to be re-tightened to 44 ft-lbs. The upper shock bolt has a small rubber washer as part of the assembly. The shop manual seems to indicate that it's supposed to be replaced when you re-assemble, but I just used the old one.
I had to increase the pre-load slightly to get 30-35mm of sag. I have no idea where to set the rebound damper. It's currently set to 25 clicks in (out of 60 clicks) from fully damped.
I paid about US$335 for the shock at current exchange rates. I didn't want to invest $600-$900 for a Penske/Ohlins. I don't race the bike, so I'm sure that the YSS will be a big improvement over the cheap stock unit for street use.
-Jeff
jgarnold is offline
post #30 of 41 (permalink) Old 09-06-2013, 04:22 AM
easy's Avatar
Send a message via MSN to easy
nice. maybe write some impressions after a few rides
easy is offline
