Can you lower the 650? : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Old 04-09-2012, 05:08 PM   #1 (permalink)
Camreno's Avatar
Camreno has at least 250 rep pointsCamreno has at least 250 rep pointsCamreno has at least 250 rep pointsCamreno has at least 250 rep points
Default Can you lower the 650?
I have the ER6n, can you lower these bikes? I have short legs :/ with both legs down at the same time im a little lower then tip toes, I would like to go down a inch or so.
Is it hard to lower these? I would take it to the shop but I know how Kawasaki likes to screw you over, 90 bucks an hour? Come on whats that...
Camreno is offline   Reply With Quote
Old 04-09-2012, 05:24 PM   #2 (permalink)
cookiebug79's Avatar
From how I understand it, you need a new shock that's a different length. They cannot be lowered by swapping out a lower link, or "dog bone" like many sport bikes.
Old 04-09-2012, 06:14 PM   #3 (permalink)
Vhayne has at least 250 rep pointsVhayne has at least 250 rep pointsVhayne has at least 250 rep pointsVhayne has at least 250 rep points
I'd like to know the answer to this as well. My friend is vertically challenged, and when I asked the dealer about his 2012 650, they said that with the current shock it's impossible.
If anyone knows of an aftermarket shock that would fix this, I'd love to know.
Vhayne is offline   Reply With Quote
Old 04-09-2012, 06:21 PM   #4 (permalink)
Camreno's Avatar
My friend at work lowered her Versys ALOT, I wonder if those are the same supensions, If so I'll ask her how she did it.
Old 04-09-2012, 06:24 PM   #5 (permalink)
YorkshireJim has at least 500 rep pointsYorkshireJim has at least 500 rep pointsYorkshireJim has at least 500 rep pointsYorkshireJim has at least 500 rep pointsYorkshireJim has at least 500 rep pointsYorkshireJim has at least 500 rep pointsYorkshireJim has at least 500 rep points
IIRC the versys shock is about 20mm shorter than the er6.
that could be your best bet.
other than that, you could remove some foam from your seat
YorkshireJim is offline   Reply With Quote
Old 04-09-2012, 06:32 PM   #6 (permalink)
Camreno's Avatar
Lol, that would be one rough ride.
Old 04-09-2012, 07:12 PM   #7 (permalink)
Glocken's Avatar
nope. done with the 1st and 2nd gens.
but yes you can lower it. just get lowering links.
but personally, i'd suggest you shave the seat/modify it. or just learn to ride it the way it is. theres no need to have both feet flat down unless you're trying to back up, which you can just get off the bike and roll it back.
you're also going to want to lower the front end with the back lowered if you do decide to do so.
'06 650R RIP
'05 Sv650s
Old 04-09-2012, 08:30 PM   #8 (permalink)
Where are the lowering links on the ER6n? Could you post a picture? I thought the shock went between the frame and the swingarm. Am I looking at the wrong thing?
Old 04-09-2012, 08:31 PM   #9 (permalink)
But I do agree. If you lower the rear, definitely lower the front. But that's easy.
Old 04-09-2012, 08:47 PM   #10 (permalink)
Nope you're looking at the right thing. Haven't gotten my hands on one up close and personal to see yet, but it does appear you need a shorter shock to lower it.
Currently own:
05 Z750S
Have owned:
01 Volusia
Wrider is online now   Reply With Quote
