Originally Posted by rjbergen
borka, I'm very interested in buying a set of the projectors, but I didn't see anywhere about how to install the demon eyes. What extra steps are required to install those?
I've read on other forums that some people have issues with the 55W HIDs melting the front clear plastic lens of the headlight housing. Do you know anything about this?
What are the corner LED lights listed on the product page? Do they go where the stock DTR lights are?
There is an option for up to 3 switches on the product page, what would 3 switches allow you to do? Does it allow for individual control of the halos, demon eyes, and HIDs separately from each other?
Hey,
Use the 250R how-to for the demon eyes install, its the same process, you simply open the projector with 4 screws and glue the demon eye rings inside.
HOW-TO: Install BKMOTO BiXenon HID projectors with angel eyes halos 2008+ Ninja 250R
I've sold lots of 55w hid kits and no one ever reported of heat or melting issues, i think you are looking at regular 55w hid kits which have more heat in the headlight, with our 55w projector hid's all the heat is trapped inside the projector, if you actually touch the clear lens where the light is emitted its not hot at all.
The corner led lights are replacement led light bulbs for the regular corner lights in your headlight, they look much better than the yellowish little halogen bulbs that are in there now.
The switches are needed if you want to control the hid's on/off, angel/demon eyes on/off etc... if you have no extra switches, then when you start the bike everything lights up, and no way to turn anything off. so each accessory needs 1 on/off switch if you want to be able to turn it off.
with demon eyes you need a minimum of 1 switch on the hids as the demon eyes are not visible unless the hid's are off.
