Aftermarket front forks for 650R? - Page 6 : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Old 09-01-2012, 04:15 PM   #51 (permalink)
Devestator's Avatar
Devestator has at least 10 rep points
Ya i couldn't find my book for a while, but i found it now and have it set right.
Another question. If i used 03-04 triples, forks, calipers, and spacers, could i use my current wheel?
'06 NINJA 650R with:
Two Brothers Aluminum Slip-on
RandG Frame Sliders
RandG Bar End Sliders
Woodcraft Spool Sliders
Street FX Red Leds
Devestator is offline   Reply With Quote
Old 09-01-2012, 04:37 PM   #52 (permalink)
I would fight Abe Lincoln
RacinJason44's Avatar
No, you would need to use an 05-12 ZX6R or 06-11 ZX10r wheel.
OMRRA Novice # 744
Old 10-10-2012, 08:40 PM   #53 (permalink)
Could we use the Ohlins TTX 25 cartridges
My bike is confused
sportyaccordy is offline   Reply With Quote
Old 10-10-2012, 08:41 PM   #54 (permalink)
Sure, if you swap in a fork that they fit.
OMRRA Novice # 744
Old 10-16-2012, 04:15 AM   #55 (permalink)
WebDC's Avatar
WebDC has at least 250 rep pointsWebDC has at least 250 rep pointsWebDC has at least 250 rep pointsWebDC has at least 250 rep pointsWebDC has at least 250 rep points
Maybe this picture might help..
Blog on ER6-N modifications
- Versys Swingarm Swap - ZX10R Fork Swap
- TWF Racing spacer with 636 wheel upgrade- Ohlins shocks
- Brembo monoblock caliper - 310mm Rotors
WebDC is offline   Reply With Quote
Old 11-06-2012, 02:54 AM   #56 (permalink)
cfernandez's Avatar
cfernandez has at least 10 rep points
I have looked over a few different posts and can't seem to find an answer, so forgive me if this has already been talked about.
I have an '09 650R that I need to replace the whole front end. Found a set a '04 636 forks, upper and lower triples, brake calipers and front wheel. The question is: I want to retain the use of handlebars. What upper triple tree can I use? Is it the z1000 upper triple which is hard to find on Craigslist or eBay? If so, what year?
I should be able to use my 650R rotors on the '04 636 front brake calipers, right? Thanks!
2009 Repaired Lime Green Ninja 650R. Gipro-DS. Woodcraft frame sliders. DeLorme PN40 GPS on RAM mount. CrampBuster for throttle control. Harbor Freight swingarm spools. Race Tech gold emulators/springs in the forks and a custom Race Tech G3-S shock. SW-Motech side rails and Givi luggage.
cfernandez is offline   Reply With Quote
Old 11-06-2012, 09:41 AM   #57 (permalink)
Z1000 is hard as hell to find. I think they make handlebar adapter kits/aftermarket 636 upper triples.
My bike is confused
Old 11-12-2012, 04:20 AM   #58 (permalink)
WebDC's Avatar
sportyaccordy is right, waited a while eventually I had to get a new Top Triple from the Z1000 for my project.
Old 11-12-2012, 09:12 AM   #59 (permalink)
HEre's a site w/a bunch of options (cartridges, emulators, etc)
Motorcycle Front Fork Cartridge Kits From Traxxion, WP Suspension and Racetech
Something else to consider: SV650 has 41mm forks and has a lot of support. So it would prob be smart to look up SV650 stuff as well.
Traxxion makes a fully adjustable drop in cartridge
AK-20 Axxion Cartridge Kit
My bike is confused
Old 12-26-2012, 05:09 PM   #60 (permalink)
abhijitz has at least 10 rep points
I just wanted to check on the swap. I have a 06 Ninja 650 and want to do the ZX-10R frontend swap. The previous owner gave me the complete ZX-10R frontend including upper/lower triples, calipers, forks.
It looks like the front wheel off the 650 will fit (same axle) but do i need to change over to the ZX-10R wheel spacers? [i saw one post from ivanko]
Also, as mentioned, the ZX-10R lower triple will not fit. I know the 636 lower triple is bolt on (but unsure of fork dia). Also i was told to use 04-ZX 6R lower triple and use that stem on the ZX-10R triple?
Appreciate your inputs !
abhijitz is offline   Reply With Quote
