Anyone successfully installed PCV on a 2012 Ninja 650? Need help! - Page 2 : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Old 11-01-2012, 03:24 PM   #11 (permalink)
Site Sponsor
DynojetResearch has at least 500 rep pointsDynojetResearch has at least 500 rep pointsDynojetResearch has at least 500 rep pointsDynojetResearch has at least 500 rep pointsDynojetResearch has at least 500 rep pointsDynojetResearch has at least 500 rep points
Originally Posted by lightmaster View Post
Should the ground wire be connected to the negative on the battery or to a screw grounding it to the frame?
The install guide says "Secure the ground eyelet of the PCV wiring harness to the ground bolt on top
of the engine case and rear of the starter (Fig M)."
So I would suggest grounding it there. If the PCV lights up when you turn the key on, it is getting power. Do you hear the fuel pump run when you turn the key on?
DynojetResearch is offline   Reply With Quote
Old 11-30-2012, 06:33 PM   #12 (permalink)
Thumper_ has at least 10 rep points
Have you attached the old cables (the ones you pulled out to attach the ones from the PCV) to the spare cables from the PCV..as the old ECU is still installed u need to trick it into thinking it still controls the pistons etc
Sent from my Nexus 7 using Motorcycle.com Free App
Thumper_ is offline   Reply With Quote
