Anyone successfully installed PCV on a 2012 Ninja 650? Need help! : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Old 10-26-2012, 03:57 PM   #1 (permalink)
lightmaster has at least 10 rep points
Default Anyone successfully installed PCV on a 2012 Ninja 650? Need help!
Wondering if anyone has successfully installed a Power Commander V on a 2012 Ninja 650. I've connected all the wires and I'm having trouble starting it with the PCV installed. It starts fine without the PCV installed tho. Tried calling their tech support line, but they weren't any help.
lightmaster is offline   Reply With Quote
Old 10-26-2012, 06:39 PM   #2 (permalink)
hanz's Avatar
hanz has at least 50 rep points
Plugs put in correct sequence ?
hanz is offline   Reply With Quote
Old 10-28-2012, 12:32 PM   #3 (permalink)
I'm pretty sure the plugs are in the right sequence. How would I know if they weren't tho? The bike just keeps trying to turn over, over and over again, making the clicking sound when I hit the start button.
Old 10-29-2012, 02:09 PM   #4 (permalink)
Site Sponsor
DynojetResearch has at least 500 rep pointsDynojetResearch has at least 500 rep pointsDynojetResearch has at least 500 rep pointsDynojetResearch has at least 500 rep pointsDynojetResearch has at least 500 rep pointsDynojetResearch has at least 500 rep points
Does the Power Commander light up when the key is turned on? It should. When the fuel pump comes on, the Power Commander should turn on. Try starting the bike with the Power Commander plugged into the computer. If it starts then, that usually indicates a poor ground.
DynojetResearch is offline   Reply With Quote
Old 10-29-2012, 10:07 PM   #5 (permalink)
redkawi650 has at least 10 rep points
recheck your wiring. every single one. maybe bad ground or not grounded???
2012 Kawasaki Ninja 650
redkawi650 is offline   Reply With Quote
Old 10-30-2012, 06:58 AM   #6 (permalink)
The power light on the PCV does turn on when I try to crank up my ninja. Makes no difference if the PCV is plugged into the computer or not.
Old 10-30-2012, 05:57 PM   #7 (permalink)
aesthetic's Avatar
aesthetic has at least 10 rep points
dont mean to derail your thread, but what exactly is a PCV? is it similar to having your ECU flashed on a car, or an engine management system?
aesthetic is offline   Reply With Quote
Old 10-30-2012, 06:01 PM   #8 (permalink)
Strider007's Avatar
Strider007 has at least 500 rep pointsStrider007 has at least 500 rep pointsStrider007 has at least 500 rep pointsStrider007 has at least 500 rep pointsStrider007 has at least 500 rep pointsStrider007 has at least 500 rep pointsStrider007 has at least 500 rep points
Power Commander V. Yes, it's a fuel management system.
2009 ZX-6R (32,000 miles and counting)
Strider007 is offline   Reply With Quote
Old 10-31-2012, 12:36 PM   #9 (permalink)
Should the ground wire be connected to the negative on the battery or to a screw grounding it to the frame?
Old 10-31-2012, 01:11 PM   #10 (permalink)
I would fight Abe Lincoln
RacinJason44's Avatar
I ran mine directly to the battery.
OMRRA Novice # 744
