Well it happened...dropped my bike :/ : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Old 11-02-2012, 06:39 PM   #1 (permalink)
06ninja650r's Avatar
06ninja650r has at least 10 rep points
Default Well it happened...dropped my bike :/
It was about 2 weeks ago now and it was a Saturday. I just finished washing my bike and figured I'd take it for a quick spin around my apartment parking lot. Well the night before I adjusted the clutch so it engaged and disengaged quicker so I was not quite used to it yet. And of course I decided not to wear protection only a helmet (I usually wear full gear) since I was just going for a spin around my parking lot. Needless to say I ended up losing control of the bike and I went down. The kickstand ended up going into my ankle causing an open wound fracture and I had severe road rash down my left side. I'm doing better and the rash has mostly healed on my arm and upper leg can't tell my lower leg since I'm in a splint. But from now on I can say no matter how far or slow I'm riding I'm riding full gear. Thankfully i was wearing my helmet and my friends were outside to help. The bike is in pretty good condition ill post a pic or two of its side.Well it happened...dropped my bike :/-imageuploadedbymo-free1351895886.152190.jpgWell it happened...dropped my bike :/-imageuploadedbymo-free1351895912.148945.jpg
Me?...Personally I use jet fuel in my bike...and as always safety third.
06ninja650r is offline   Reply With Quote
Old 11-02-2012, 06:56 PM   #2 (permalink)
Islesfan91 has at least 10 rep points
Shitty to hear, hope you heal up soon. I wrecked my 2011 650 in June and now riding the 2012 650. It was almost more painful not having a bike.
Islesfan91 is offline   Reply With Quote
Old 11-02-2012, 07:12 PM   #3 (permalink)
Yea it's tough. I think my clutch case might have a small crack in it too. So I might try to jb weld it. But it's tough being stuck in a wheelchair and not being able to ride. Thanks for the wishes mate! Enjoy that 2012, mines a 2006.
Old 11-02-2012, 07:29 PM   #4 (permalink)
Definitely loving it, although my thumb is still sprained but the foot and ribs have healed nicely. Don't rush yourself and use the winter to fix anything on the bike that's broken
Old 11-02-2012, 07:40 PM   #5 (permalink)
ER^NSLIMS's Avatar
ER^NSLIMS has at least 2000 rep pointsER^NSLIMS has at least 2000 rep pointsER^NSLIMS has at least 2000 rep pointsER^NSLIMS has at least 2000 rep pointsER^NSLIMS has at least 2000 rep pointsER^NSLIMS has at least 2000 rep pointsER^NSLIMS has at least 2000 rep pointsER^NSLIMS has at least 2000 rep pointsER^NSLIMS has at least 2000 rep pointsER^NSLIMS has at least 2000 rep pointsER^NSLIMS has at least 2000 rep points
Crack in the stator cover if it was on the left side. Sucks, heal fast.
New out of the box Triumph S3.
ER^NSLIMS is offline   Reply With Quote
Old 11-02-2012, 08:01 PM   #6 (permalink)
Ok thanks! And sadly I'm in Florida for college but I don't plan on rushing anything. I want to make sure I'm healed before riding again.
Old 11-02-2012, 09:11 PM   #7 (permalink)
PeaPod has at least 10 rep points
Good luck with that! You'll get the itch much earlier than you will heal.
Sorry for your down. Hope you do get well quick. What is up with the frame slider? That thing is bent up and does not look like it helped much. What kind is it?
PeaPod is offline   Reply With Quote
Old 11-02-2012, 09:43 PM   #8 (permalink)
It's attached around the frame rather than to it and since the bike hit the ground and slid I think it moved it up. But it did its job the frame isn't bent and the engine is all good. This is the second time the bike has been dropped on its left side, when my uncle owned it he dropped it on its left which moved the slider a bit so I loosened the screws readjusted it and then tightened. So it tends to move but seems to have worked so far.
Old 11-02-2012, 11:24 PM   #9 (permalink)
ShinobiJeh's Avatar
i have similar-looking frame sliders and was wondering the same thing... I don't know what kind they are, and I've never taken the top fairing off, don't plan to either.
Maybe I will go and check mine, see if mine are attached to frame or around it.
Old 11-02-2012, 11:44 PM   #10 (permalink)
Glocken's Avatar
those are r&g frame sliders
'06 650R RIP
'05 Sv650s
