got recall done and not happy...brake touches plate.HELP - KawiForums - Kawasaki Motorcycle Forums
post #1 of 7 (permalink) Old 11-02-2012, 07:21 PM Thread Starter
speed_ga's Avatar
ok i go to pick up my bike today after i got the 09 650r recall done. well the brake touches the newly installed plate. is there anyway to correct this?
in the last pic i have my hand holding thr pedal down a lil bit. its starting to scrap the plate a little bit as well.
Sent from my SGH-T679 using Motorcycle.com Free App
ID:	52005   Click image for larger version
ID:	52006   Click image for larger version
ID:	52007   Click image for larger version
speed_ga is offline
post #2 of 7 (permalink) Old 11-02-2012, 07:36 PM
ER^NSLIMS's Avatar
Take it back, that looks like a hack job. Hyosung had better fit and finish, lol
New out of the box Triumph S3.
ER^NSLIMS is offline
post #3 of 7 (permalink) Old 11-02-2012, 09:19 PM
Strange, i've seen other bikes that does not have the lever touch the plate. Either u got a bad plate, or bad fitting job or a bent lever.
andrewhtf is offline
post #4 of 7 (permalink) Old 11-03-2012, 07:23 AM
Zandit's Avatar
I'd say the issue is with the brake pedal. The plate looks identical to the one on my bike, and I have clearance.
Has the bike ever been dropped on that side?
2010 Kawasaki Ninja 650R ABS Island Metallic Blue.
PC5, Yoshi Exhaust, Sport Bars 3.0, Driven D3 Grips,Pirelli Angel Tyres, CF Rimtape, Bar ends & Spools, Givi Luggage, New Ninja Decals, Double Adjustable Levers, TonyBKK's Frame Sliders, Zero Gravity DB Windscreen in Dark Smoke, Narva +120% Headlights, and one Awesome Wing Nut between the seat and Handle bars!!!!
Zandit is offline
post #5 of 7 (permalink) Old 11-03-2012, 08:08 AM
goingtoscotland's Avatar
You guys know you can adjust the brake pedal height, right?
Perhaps it's just adjusted rather high for some reason.
All that said you shouldn't be here asking us, you should be at the shop that performed the recall taking the issue up with them. If they fucked something up, they should be rectifying the issue.
goingtoscotland is offline
post #6 of 7 (permalink) Old 11-03-2012, 11:43 AM Thread Starter
speed_ga's Avatar
Yeah if I can just adjust the brake pedal than i would rather do that then take it back and have them hack on it some more. I don't like going to dealers at all.
speed_ga is offline
post #7 of 7 (permalink) Old 11-03-2012, 11:45 AM
If it's adjusted properly and it still does that you need to take it back to the dealer.
Their problem, they need to fix it.
