New 650 Owner - Oil Change Time : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Old 11-03-2012, 12:31 PM   #1 (permalink)
CTI
CTI has at least 10 rep points
Default New 650 Owner - Oil Change Time
Hello,
I am new to biking and bought a 2012 650. I am looking to do and oil change as winter in pretty much arrived in my neck of the woods.
I have 700KM on the bike and bought everything I need to perform the oil change as I don't have a dealer nearby.
I have the Service Manual (downloaded from web) and am a little confused by really how much of the fairing it instructs you to take off to do the oil change. I am thinking this can't be right.
Does somebody have experience with doing the oil change on the 2012 and can let me know how much of the fairing really needs to be removed in order to perform a simple oil change.
Thank you in advanced.
CTI is offline   Reply With Quote
Old 11-03-2012, 12:58 PM   #2 (permalink)
ER^NSLIMS's Avatar
ER^NSLIMS has at least 2000 rep pointsER^NSLIMS has at least 2000 rep pointsER^NSLIMS has at least 2000 rep pointsER^NSLIMS has at least 2000 rep pointsER^NSLIMS has at least 2000 rep pointsER^NSLIMS has at least 2000 rep pointsER^NSLIMS has at least 2000 rep pointsER^NSLIMS has at least 2000 rep pointsER^NSLIMS has at least 2000 rep pointsER^NSLIMS has at least 2000 rep pointsER^NSLIMS has at least 2000 rep points
This is why I buy naked bikes No, really... someone will chime in, and the answer is, only as much as you have to... the lowers Id suspect.
Some guys have posted here that instead of removing the fairing, they loosened it and pulled it apart at the bottom to access the filter etc... then buttoned it back up.
Oh how I hate bikes with prissy fairings!!
New out of the box Triumph S3.
ER^NSLIMS is offline   Reply With Quote
Old 11-03-2012, 07:45 PM   #3 (permalink)
hanz's Avatar
hanz has at least 50 rep points
Just take right side off, it's pretty easy, the bottom piece black area of fairing is connected to top portion it all comes off one piece
hanz is offline   Reply With Quote
Old 11-04-2012, 10:47 PM   #4 (permalink)
boostm3 has at least 10 rep points
Some guys find they dont have to remove fairings completely; just loosen.
boostm3 is offline   Reply With Quote
Old 11-05-2012, 02:11 AM   #5 (permalink)
taotaomona77@yahoo.com's Avatar
taotaomona77@yahoo.com has at least 500 rep pointstaotaomona77@yahoo.com has at least 500 rep pointstaotaomona77@yahoo.com has at least 500 rep pointstaotaomona77@yahoo.com has at least 500 rep pointstaotaomona77@yahoo.com has at least 500 rep pointstaotaomona77@yahoo.com has at least 500 rep pointstaotaomona77@yahoo.com has at least 500 rep points
Initially I removed one side of the fairing, but as the earlier post stated you can just loosen and get to the filter.
2012 Ninja EX650 ~ Metallic Spark Black
Painted Windscreen (black), Rear Fender Eliminator...
taotaomona77@yahoo.com is offline   Reply With Quote
Old 11-06-2012, 10:40 PM   #6 (permalink)
tony650 has at least 10 rep points
I have a 2012 with 1050 miles.You only need to take right side off. I just changed my oil and pulled both sides off so I could check torque on fasteners throughout the bike. It was a good thing I did too,all fasteners were good except the header bolts,they were so loose I am surprized they didnt fall off. I change to full synthetic also and can tell the difference in shifting and engine noise. (the engine noise was probably the headers)
tony650 is offline   Reply With Quote
