I'm curious I was wondering..... : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Old 11-21-2012, 04:36 PM   #1 (permalink)
Carr3344 has at least 10 rep points
Default I'm curious I was wondering.....
I wanted to do an upgrade to my braking system. My friend was telling me that I should try and swap the front Master cylinder with an R6 unit(idk which year). Has anybody done this mod if so how do you like it and what would I need to buy in order to swap it?
Carr3344 is offline   Reply With Quote
Old 11-21-2012, 07:57 PM   #2 (permalink)
Veteran Lowsider
Ninjabadger4's Avatar
For starters I would change the front brake lines to stainless steel. It improves the firmness in the lever and keeps the moisture out of the system
Old 11-21-2012, 08:07 PM   #3 (permalink)
Glocken's Avatar
unless you're really that hard on your brakes, SS lines and brake pads should be enough.
idk what year you had, but my 1st gen had minor brake fade during aggressive riding/usage. if nothing was changed in the brake setup for all 3 gens, ss lines would make a big difference.
Elka 3 way shock|Penske fork valves|Leo full titanium & CF|Hyperpro steering damper|GB frame slider & engine casings|Woodcraft clipons|Pazzos|ZG|Proton
Old 11-21-2012, 08:08 PM   #4 (permalink)
Veteran Lowsider
Flush/bleed the brakes too
Old 11-21-2012, 08:21 PM   #5 (permalink)
Sev
The Indifference Engine
Sev's Avatar
Sev has between 30,000 and 40,000 rep pointsSev has between 30,000 and 40,000 rep pointsSev has between 30,000 and 40,000 rep pointsSev has between 30,000 and 40,000 rep pointsSev has between 30,000 and 40,000 rep pointsSev has between 30,000 and 40,000 rep pointsSev has between 30,000 and 40,000 rep pointsSev has between 30,000 and 40,000 rep pointsSev has between 30,000 and 40,000 rep pointsSev has between 30,000 and 40,000 rep pointsSev has between 30,000 and 40,000 rep points
Probably too much master cylinder for the calipers you have.
Old 11-22-2012, 09:05 AM   #6 (permalink)
SS lines won't keep out moisture of reduce fade, but it's easy to think that they do if the original lines are less than perfect. They do slightly increase the firmness of the brakes.
Changing a master cylinder isn't really an upgrade. What it can do, by altering the piston diameter, and therefore the leverage ratio, is alter the lever travel and amount of lever pressure needed. Less travel means you need more pressure and vice versa. It's more about tuning the system for your personal taste.
Old 11-23-2012, 01:22 AM   #7 (permalink)
ivanko's Avatar
ivanko has at least 1500 rep pointsivanko has at least 1500 rep pointsivanko has at least 1500 rep pointsivanko has at least 1500 rep pointsivanko has at least 1500 rep pointsivanko has at least 1500 rep pointsivanko has at least 1500 rep pointsivanko has at least 1500 rep pointsivanko has at least 1500 rep pointsivanko has at least 1500 rep pointsivanko has at least 1500 rep points
I would switch your pads, flush, bleed and go from there. i would not use a different MC waste of time and money for those brakes
ivanko is offline   Reply With Quote
Old 11-26-2012, 12:32 PM   #8 (permalink)
I have ss brake lines and I love them and I have good brake pads I just heard that the R6 stock set up is equivalent to a brembo brake set up so I was interested in that. But you guys are right i think it's about time for a bleed job and some new pads.
Yamaha Motorcycles Victory Gunner Forum Honda Vultus Forum HD LiveWire Forum Ninja H2 Forum Ducati Scrambler Forum Kawasaki Ninja 250SL Forum
