2013 Kawasaki Ninja 650 Idle speed? am I doing something wrong here? : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Old 11-23-2012, 10:25 PM   #1 (permalink)
SALTxTHExWOUND's Avatar
SALTxTHExWOUND has at least 10 rep points
Default 2013 Kawasaki Ninja 650 Idle speed? am I doing something wrong here?
the manual says to let it idle between 1,250 - 1,350 RPM which in my mind means 1,300 RPM should be fine... We'll when I set my idle lower than 1,500 RPM's the idle needle bumps up and down not much at all like 100 RPM but say if I set it to 1,300 RPM it will bump back and forth between 1,300 RPM and 1,400 RPM. Is that normal for the idle needle to bounce like that? I never noticed it on my other bikes but maybe I'm just being paranoid... can anyone help me out please! Thanks in advance, I'm trying to explain it the best I can. Honestly the only time I can get it to stay at one constant RPM is when it's at around 1,500 RPMs
2013 Kawasaki Ninja 650 - Yoshimura fender eliminator, Yoshimura frame sliders, Pit bull swing arm spools
SALTxTHExWOUND is offline   Reply With Quote
Old 11-24-2012, 08:48 AM   #2 (permalink)
636karl's Avatar
636karl has at least 1000 rep points636karl has at least 1000 rep points636karl has at least 1000 rep points636karl has at least 1000 rep points636karl has at least 1000 rep points636karl has at least 1000 rep points636karl has at least 1000 rep points636karl has at least 1000 rep points636karl has at least 1000 rep points636karl has at least 1000 rep points
Are you doing the adjustment with the engine fully warmed up?
636karl is offline   Reply With Quote
Old 11-24-2012, 11:53 AM   #3 (permalink)
Yeah, I mean I've played with it a few times and it'll stay at a steady idle but after riding for a while it will go up or down a little bit, is that normal for the 650? I can just leave it at 1,500 RPM idle speed if that won't hurt the bike at all but im not sure if it will?
Old 11-26-2012, 05:28 AM   #4 (permalink)
1500 rpm won't hurt it, but it should be steady at 1300 as long as the motor is fully up to temperature - after about 5 or 6 miles. (The oil takes another 5 or 6 miles to filly heat up)
If the bike is new it might still be a bit tight. If it hasn't had its first service yet, get the dealer to check it with the service.
Old 11-30-2012, 05:53 PM   #5 (permalink)
akaMatt has at least 10 rep points
i have mine set to 1000... seems more 'normal'... 1300 seemed WAY too high...
2009 Ninja 650r: Black/Gray, Arrow Muffler, Fender Eliminator
akaMatt is offline   Reply With Quote
Old 11-30-2012, 07:11 PM   #6 (permalink)
Powerhungry
nevada's Avatar
1000 is too low.
and, mine, while not a 650 also bounces a bit. i dont care.
how often does it sit idling anyway.
Old 11-30-2012, 10:37 PM   #7 (permalink)
Originally Posted by nevada View Post
1000 is too low.
Yeah good point, It only bounces every now and then but didn't know if this is a normal thing with twin cylinders or not? What kinda bike do you have and how much would you say it bounces?
Old 12-04-2012, 10:15 PM   #8 (permalink)
1000 is too low.
what do u mean by 'bounces'? and what do u have? not the same bike/engine, not same results... mine idles perfect at 1000, no problems at all, never stalls... it even idles perfect at 750, but thats too low...
