How to remove spring to paint : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Old 11-29-2012, 01:39 AM   #1 (permalink)
evolDiesel has at least 10 rep points
Default How to remove spring to paint
Hey guys,
Has anyone removed the rear spring? I'm painting my ER6N and want to do the spring while I'm at it. Looks like I need a special tool. Tips/Tricks?
Sent from my SCH-I535 using Motorcycle.com Free App
2009 ER-6N
Low Bars, Bar end mirrors, 650R caps, FE, Motodynamics Sequential Integrated Tail, Adj Shorty Levers, Ogio MX MiniTanker
evolDiesel is online now   Reply With Quote
Old 11-29-2012, 02:37 AM   #2 (permalink)
SuperCheese88's Avatar
SuperCheese88 has at least 80,000 rep pointsSuperCheese88 has at least 80,000 rep pointsSuperCheese88 has at least 80,000 rep pointsSuperCheese88 has at least 80,000 rep pointsSuperCheese88 has at least 80,000 rep pointsSuperCheese88 has at least 80,000 rep pointsSuperCheese88 has at least 80,000 rep pointsSuperCheese88 has at least 80,000 rep pointsSuperCheese88 has at least 80,000 rep pointsSuperCheese88 has at least 80,000 rep pointsSuperCheese88 has at least 80,000 rep points
Why not just slip a newspaper inside the coils and tape the stuff off? Then you won't have to reset the spring after.
Join PWT and waste time with us
http://www.kawiforums.com/nws/202816...oes-vegas.html
SuperCheese88 is offline   Reply With Quote
Old 11-29-2012, 05:18 AM   #3 (permalink)
If you don't have a spring compressor the easiest way to remove it is to fit the shock on to the bike and get somebody to sit on it while you twist some wire around the top and bottom coils of the spring so that when the weight's taken off it can't stretch.
Then it's easy to slip out the collets and remove the spring. Leave the wire around the spring to keep it compressed until it's refitted.
No resetting involved ecxept you'll obviously have to re-set the preload adjustment. Best to have the shoch refitted and weight on the bike before trying to remove or cut the wire.
Old 11-29-2012, 08:27 PM   #4 (permalink)
cw4444 has at least 10 rep points
I was in the same place about a month ago. Seems like the easiest way is to get spring compressors. Unfortunately no one in my town sells them and I am impatient. What I did was take 2 aluminum plates. I drilled a 2 1/2" hole in one to fit behind the spring adjuster. I drilled a 3" hole in the other plate to fit over the other end of the shock. I joined the two plates with threaded rod. I tightened down nuts on the threaded rods to compress the spring. Worked flawlessly.
cw4444 is offline   Reply With Quote
Old 11-30-2012, 05:40 AM   #5 (permalink)
What you've done is made a spring compressor. You can do that for a lot of special tools.
Old 12-04-2012, 01:10 PM   #6 (permalink)
paint:
ER-6N PICs
2009 ER-6N
