Strange sounds : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Old 11-29-2012, 04:24 AM   #1 (permalink)
KillSwitch's Avatar
KillSwitch has at least 250 rep pointsKillSwitch has at least 250 rep pointsKillSwitch has at least 250 rep pointsKillSwitch has at least 250 rep pointsKillSwitch has at least 250 rep points
Send a message via Skype™ to KillSwitch
Default Strange sounds
Hi guys
Since yesterday, I've been hearing this strange grinding/buzzing noise whenever I twist the throttle, but if I disengage the clutch the noise disappears.
It's not very loud, because at higher rpm the exhaust tone drowns it out.
Could this be bearing related?
Words of wisdom most welcome
Cheers
KillSwitch is offline   Reply With Quote
Old 12-03-2012, 09:38 PM   #2 (permalink)
Island Ninja's Avatar
Island Ninja has at least 10 rep points
how old is your bike?
is the noise rpm related?
Sent from my GT-I9300 using Motorcycle.com Free App
Island Ninja is offline   Reply With Quote
Old 12-04-2012, 03:53 PM   #3 (permalink)
KillSwitch's Avatar
It's a 2011 with around 10000km
I checked today and it doesn't seem to be rpm related
Old 12-04-2012, 04:16 PM   #4 (permalink)
So. Florida's Squid
venom400's Avatar
venom400 has between 10,000 and 20,000 rep pointsvenom400 has between 10,000 and 20,000 rep pointsvenom400 has between 10,000 and 20,000 rep pointsvenom400 has between 10,000 and 20,000 rep pointsvenom400 has between 10,000 and 20,000 rep pointsvenom400 has between 10,000 and 20,000 rep pointsvenom400 has between 10,000 and 20,000 rep pointsvenom400 has between 10,000 and 20,000 rep pointsvenom400 has between 10,000 and 20,000 rep pointsvenom400 has between 10,000 and 20,000 rep pointsvenom400 has between 10,000 and 20,000 rep points
Could it be vibration related? like something lose ?
Other than maybe a worn clutch bearing ? I don't have a lot of experience with bikes on a car this would be my diagnosis , a video or a .recording would help.
Squid.
venom400 is offline   Reply With Quote
Old 12-05-2012, 06:49 PM   #5 (permalink)
av8r-92's Avatar
When it starts to make the noise, try putting a finger on the brake and clutch levers. Those can sometimes make noise when they vibrate.
-Will
KEEP CALM AND CHIVE ON
"Trust me; I'm a pilot."
Old 12-06-2012, 03:27 AM   #6 (permalink)
KillSwitch's Avatar
-Will
I'll give that a try on my way home today and let you guys know.
Old 12-06-2012, 06:22 AM   #7 (permalink)
Gantt's Avatar
Gantt has at least 1000 rep pointsGantt has at least 1000 rep pointsGantt has at least 1000 rep pointsGantt has at least 1000 rep pointsGantt has at least 1000 rep pointsGantt has at least 1000 rep pointsGantt has at least 1000 rep pointsGantt has at least 1000 rep pointsGantt has at least 1000 rep points
My fuel cap sometimes has some vibrations. Press down on it too. Mine started around. 2,000 miles.
Sent from my Bagphone.
Gantt is online now   Reply With Quote
Old 12-11-2012, 01:21 AM   #8 (permalink)
ncifong has at least 10 rep points
had the same problem with my bike.. ended up it is the new short levers that I have installed. The right side lever's "expandable" potion is a bit loose, which creates the buzzing sound.
My friend's case is cause his exhaust was fitted a bit loose, which causes the buzzing sound.
ncifong is offline   Reply With Quote
Old 12-11-2012, 06:42 AM   #9 (permalink)
WhoUtink's Avatar
WhoUtink has at least 50 rep points
Levers, your key/keys, lights, cables, fairings, everything can buz from vibration of the engine lol, you can let it drive you crazy or just ignore it. Unless you think it is a mechanical malfunction then you might wanna try to pinpoint the noise.
My head light buzzes. I heard it a couple of times then I decided to find it. While riding, just start touching things with a firm pressure and see if the noise changes or goes away. I'm going to add in some rubber washers at the mounting points hopefully solves my problem.
WhoUtink is offline   Reply With Quote
