ER-6N indicator help : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Old 12-10-2012, 08:06 AM   #1 (permalink)
bikemanrob has at least 10 rep points
Default ER-6N indicator help
yo everyone,
Started to do a few mods to the er6, Bought a tail-tidy, LED indicators, Tank pad and a few other bits.
What will i need in order for the LED indicators to flash at the correct rate inline with the front standard indicators? Is it just a case of bunging a LED relay in? By doing this will it effect the flashing of the front indicators?
Many thanks, Im not clued up on the electrics side haha
bikemanrob is offline   Reply With Quote
Old 12-10-2012, 08:09 AM   #2 (permalink)
You need a solid state switching relay. A LED relay basically does this, but some of them only work properly if the front indies are LED as well.
Check with the supplier of your relay.
Old 12-10-2012, 09:10 AM   #3 (permalink)
Cheers
Could you fire me a link to a solid state switching relay?
So your saying i can use a LED relay perfectly fine as-long as i check with the seller there compatible with both bulbs and LEDs?
Old 12-10-2012, 12:37 PM   #4 (permalink)
Just found this beast on ebay,
I take it this will work with both sets of indicators?
Acumen Electronics Kawasaki Flasher Relay Wide range Relay | eBay
And a more expensive one,
KAWASAKI ZX6R ZX7 ZX9 ZX10R Electronic Flasher relay LED indicators ZX6 | eBay
Advice Appreciated
Old 12-11-2012, 10:53 PM   #5 (permalink)
reddoak has between 5,000 and 7,500 rep pointsreddoak has between 5,000 and 7,500 rep pointsreddoak has between 5,000 and 7,500 rep pointsreddoak has between 5,000 and 7,500 rep pointsreddoak has between 5,000 and 7,500 rep pointsreddoak has between 5,000 and 7,500 rep pointsreddoak has between 5,000 and 7,500 rep pointsreddoak has between 5,000 and 7,500 rep pointsreddoak has between 5,000 and 7,500 rep pointsreddoak has between 5,000 and 7,500 rep pointsreddoak has between 5,000 and 7,500 rep points
Or you could wire a resistor into the circuit.
2008 Passion Red Ninja 250 - Sold!
2009 Plasti-dip black ER-6N
reddoak is offline   Reply With Quote
Old 12-12-2012, 11:30 AM   #6 (permalink)
dazo's Avatar
dazo has at least 250 rep pointsdazo has at least 250 rep pointsdazo has at least 250 rep points
I wired in new LED turn signals for the back (competition werkes) and they flash at an acceptable rate for me, seems close to the original rate to me. I left the front signals stock so that might be offering enough resistance to keep them from flashing too fast. I would say to try it without an added resistor first and see what you think. I have a friend with an FZ1 that wired LEDs in for front and back along with an integrated tail light, his flash pretty fast, but he just left it that way. I didn't think it was all that bad either. I can still tell he is signalling to turn.
dazo is offline   Reply With Quote
Old 12-12-2012, 12:36 PM   #7 (permalink)
Cheers guys, All makes sense now Thanks for the reply's!
Old 12-12-2012, 01:49 PM   #8 (permalink)
Check the flash rate is between 60 and 120 flashes per minute. It's checked as part of the MOT.
LED relay should be OK, but do check.
Alternatively an 8 ohm relay fitted between each of the leds and ground will restore the original flash rate. Resistor should be a wire wound one rated at about 5W. Actual loading is a fair bit higher, but it's only flashing intermittently for a few seconds at a time.
Old 12-12-2012, 02:33 PM   #9 (permalink)
Nice, Thanks for the info bud, I will get a couple resistors on order this week .
