09 650r won't start - KawiForums - Kawasaki Motorcycle Forums
post #1 of 9 (permalink) Old 12-13-2012, 02:31 AM Thread Starter
Unhappy 09 650r won't start
Hello Folks,
I was riding home from work today and stopped by a ATM. When I tried to start the bike after getting cash it would not start. The starter is cranky fine. One thing I notice is I don't hear the fuel pump whine when you turn on the bike so I don't think it's getting any fuel. Is there a fuse for the fuel pump that I can check? With my luck I probably need a new fuel pump. I would greatly appreciate any advice or suggestions at this point.
Thank you!
ninja420 is offline
post #2 of 9 (permalink) Old 12-13-2012, 08:58 AM
There is a fuel pump fuse in the fusebox under the seat.
williamr is offline
post #3 of 9 (permalink) Old 12-13-2012, 12:20 PM Thread Starter
Thanks Rob. There wasn't one label fuel pump but I checked all the fuses and they look fine. Maybe there is a loose connection or a short somewhere. I guess I need to tow it to a shop.
ninja420 is offline
post #4 of 9 (permalink) Old 12-13-2012, 02:58 PM
I would fight Abe Lincoln
RacinJason44's Avatar
Does it crank?
OMRRA Expert # 440
RacinJason44 is offline
post #5 of 9 (permalink) Old 12-13-2012, 03:56 PM Thread Starter
Does it crank?
It cranks hard so I don't think it's the battery.
ninja420 is offline
post #6 of 9 (permalink) Old 12-13-2012, 03:58 PM
Yeah, that also eliminates the chance it could be a clutch or neutral sensor giving you your issue. It could be a fuel pump or the fuse to it, definitely check that. Is the bike stock?
OMRRA Expert # 440
post #7 of 9 (permalink) Old 12-13-2012, 05:15 PM Thread Starter
If the fuse for the fuel pump is in the fuse box underneath the seat then that appears to be fine. I checked all the fuses in the box just in case. They all look normal.
The bike is stock except for HIDs, Arrow exhasut, LED taillight, and de-snorkel.
I decided to tow the bike home and see if I can figure out what the culprit is. Right now I'm thinking its a short and a loose connection somewhere. I probably need to pull the tank and take a peek.
ninja420 is offline
post #8 of 9 (permalink) Old 01-03-2013, 05:31 PM Thread Starter
Update: It turn out to be a bad fuel pump. I replaced the fuel pump and all is gravy now. Thanks to all that replied.
ninja420 is offline
post #9 of 9 (permalink) Old 01-18-2013, 11:46 AM
Leggz's Avatar
Send a message via AIM to Leggz Send a message via Yahoo to Leggz
Did you catch a good deal on your fuel pump, I think I might need to buy one myself.
"Kiley" - '09 Ninja 650R - Vibration is my friend
Simple but clean: black tank pad; red reflective rim tape; 12V cigarette lighter adapter; carbon fiber gas cap cover; arrow slip-on exhaust; blacked out wind screen; custom windscreen decals
Leggz is offline
