09 650r won't start : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Old 12-13-2012, 01:31 AM   #1 (permalink)
ninja420 has at least 10 rep points
Unhappy 09 650r won't start
Hello Folks,
I was riding home from work today and stopped by a ATM. When I tried to start the bike after getting cash it would not start. The starter is cranky fine. One thing I notice is I don't hear the fuel pump whine when you turn on the bike so I don't think it's getting any fuel. Is there a fuse for the fuel pump that I can check? With my luck I probably need a new fuel pump. I would greatly appreciate any advice or suggestions at this point.
Thank you!
ninja420 is offline   Reply With Quote
Old 12-13-2012, 07:58 AM   #2 (permalink)
There is a fuel pump fuse in the fusebox under the seat.
Old 12-13-2012, 11:20 AM   #3 (permalink)
Thanks Rob. There wasn't one label fuel pump but I checked all the fuses and they look fine. Maybe there is a loose connection or a short somewhere. I guess I need to tow it to a shop.
Old 12-13-2012, 01:58 PM   #4 (permalink)
I would fight Abe Lincoln
RacinJason44's Avatar
Does it crank?
OMRRA Novice # 744
Old 12-13-2012, 02:56 PM   #5 (permalink)
Does it crank?
It cranks hard so I don't think it's the battery.
Old 12-13-2012, 02:58 PM   #6 (permalink)
Yeah, that also eliminates the chance it could be a clutch or neutral sensor giving you your issue. It could be a fuel pump or the fuse to it, definitely check that. Is the bike stock?
OMRRA Novice # 744
Old 12-13-2012, 04:15 PM   #7 (permalink)
If the fuse for the fuel pump is in the fuse box underneath the seat then that appears to be fine. I checked all the fuses in the box just in case. They all look normal.
The bike is stock except for HIDs, Arrow exhasut, LED taillight, and de-snorkel.
I decided to tow the bike home and see if I can figure out what the culprit is. Right now I'm thinking its a short and a loose connection somewhere. I probably need to pull the tank and take a peek.
Old 01-03-2013, 04:31 PM   #8 (permalink)
Update: It turn out to be a bad fuel pump. I replaced the fuel pump and all is gravy now. Thanks to all that replied.
Old 01-18-2013, 10:46 AM   #9 (permalink)
Leggz's Avatar
Leggz has at least 4000 rep pointsLeggz has at least 4000 rep pointsLeggz has at least 4000 rep pointsLeggz has at least 4000 rep pointsLeggz has at least 4000 rep pointsLeggz has at least 4000 rep pointsLeggz has at least 4000 rep pointsLeggz has at least 4000 rep pointsLeggz has at least 4000 rep pointsLeggz has at least 4000 rep pointsLeggz has at least 4000 rep points
Send a message via AIM to Leggz Send a message via Yahoo to Leggz
Did you catch a good deal on your fuel pump, I think I might need to buy one myself.
"Kiley" - '09 Ninja 650R - Vibration is my friend
Simple but clean: black tank pad; red reflective rim tape; 12V cigarette lighter adapter; carbon fiber gas cap cover; arrow slip-on exhaust; blacked out wind screen; custom windscreen decals
Leggz is offline   Reply With Quote
