Lowering Kit question on 2012 : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Old 01-02-2013, 06:12 AM   #1 (permalink)
MrFett has at least 10 rep points
Default Lowering Kit question on 2012
Anyone have this? If so how do they like it? how does it change the ride? Where did you buy it and how hard is it to put on?
Sorry for all the questions, I am curious because it looks good but dont wanna dislike riding it.
MrFett is offline   Reply With Quote
Old 01-03-2013, 05:45 AM   #2 (permalink)
It alters the leverage ratio on the rear shock, so you might need to change the spring and damping rates.
Unless you drop the front yolks down the forks you alter the head angle, which makes the steering slower. If you do, you reduce the ground clearance by enough to take the fun out of hard cornering. You might also need to shorten the side stand.
Generally, unless you're shorter than about 5'0" you're better concentrating on your slow riding skills so that you don't need to lower the bike.
Old 01-03-2013, 09:16 AM   #3 (permalink)
Kawikid72's Avatar
It's going to change the way the bike handles and rides, looking good always isn't the best for the rider.
Whore your slut out
Old 01-03-2013, 02:49 PM   #4 (permalink)
Glocken's Avatar
dont do it. especially if youre only doing it because "it looks good"
'06 650R RIP
'05 Sv650s
Old 01-03-2013, 11:31 PM   #5 (permalink)
Default Thanks
This is why I asked haha, It looks good but if it doesn't do anything for the ride but instead takes away from it then f that I am all set haha
Old 01-07-2013, 03:33 PM   #6 (permalink)
Geordie's Avatar
Geordie has at least 10 rep points
Was looking at the lowering kit but decided on lowered seat which doesn't look too bad
Geordie is offline   Reply With Quote
Old 01-07-2013, 04:40 PM   #7 (permalink)
Glocken's Avatar
i'm just wondering, but how short are you guys inseam to lower the er6; isnt that thing already at like 28-29 inch seat height? thats like the same height of the 250
'06 650R RIP
'05 Sv650s
Old 01-08-2013, 02:56 PM   #8 (permalink)
Geordie's Avatar
Glocken im5'2 lol short arse and 125lb
Old 01-08-2013, 05:14 PM   #9 (permalink)
Glocken's Avatar
but whats your inseam? i'm 5'6 - 5'7 but my inseam is 28"
'06 650R RIP
'05 Sv650s
Old 01-08-2013, 05:36 PM   #10 (permalink)
Geordie's Avatar
26 mate still on toes with lowered seat I don't have a problem with this as I've never planted both feet on any of my bikes
Suspension is usually the issue
