er6n 09 C9F stick coils..... - KawiForums - Kawasaki Motorcycle Forums
post #1 of 5 (permalink) Old 05-31-2017, 06:39 AM Thread Starter
Hi guys
I went to change my plugs and discovered that one of the stick coils has rusted away and the plastic casing has cracked...was a pain in the arse to take it off...
So had a look online and its a very common thing with these coils. Many people suggested to get the mitsubishi ones that are much better quality!
So thats what i did, went on ebay and found a pair for 60 quid and the listing says compatible with ER6 2006-2015, so far so good.
Just received them and measure the coils
So
Coil A primary is 1.4-1.5 Ohm and secondary is 9.4 ish KOhm
Coil B primary is 1.4-1.5 Ohm but secondary is 9.7 ish Kohm
So the secondary is slightly different in each one and they are both out of range in my service manual :
Stick Coil Winding Resistance
Primary Windings: 1.1 ∼ 1.5 Ω
Secondary Windings: 10.8 ∼ 16.2 kΩ
So im guessing I cant use them on my bike??
Sorry for the long post!
dblane79 is offline
post #2 of 5 (permalink) Old 06-03-2017, 11:51 AM
If your unsure I'd just slap on some OEM and make sure to grease em good.
dropkicknick is offline
post #3 of 5 (permalink) Old 06-05-2017, 05:26 PM Thread Starter
I think i might risk it and give them a go :-/
The guy said they came out from another er6...
Cheers m8
dblane79 is offline
post #4 of 5 (permalink) Old 06-11-2017, 02:22 PM
did you take in to account the resistance of your leads??? i wouldnt be bothered by under 1 ohm off spec to be honest.
marf is offline
post #5 of 5 (permalink) Old 06-15-2017, 02:59 AM Thread Starter
ok m8 cheers
just when i measure the original ones are inside the range
nvm i will give them a go!
when i have some free time from bloody work!!
thanks
dblane79 is offline
