i use kerosene for my chain...and my plastics and wheels too actually. It takes out grime like nothing else...great stuff!
-Cody
Appreciate the insight guys. Probably going to go with kerosene then if it's less fumes. Yea definitely don't clean the chain without the bike running. I thought about doing that once, but I figured it was safer for my hand to manually turn the tire. But I did see a f**ked up photo where some1's fingers were torn off from cleaning the chain in 1st gear, not pretty.
Just take a small gas can to a gas station that has diesel. It's $4/gal instead of $8. There are no real appreciable fumes from the diesel if you're just using it with a rag and brush.
I've been riding for 45 years and have used WD 40 to clean the chains, then use a good lubricant. Most of my chains have lasted at least 15K miles. Just my $0.02.
I only ride on remote, backwoods roads and ride VERY agressively....probably averaging over 120 most of the way, for 30 or 40 miles one way...the twisties kinda slow me down a bit. Hell, I'm extremely lucky to get 1,900 miles out of any brand tire. I don't do any stunting or burnouts. The sprocket usually starts to show a bit of wear and tear at about 15K, so I change out the chain and sprockets to be on the safe side.
Holy Crap!! Over $20 for 2.5 gallons? Use diesel or kero from a gas station. like others suggested. One of those grunge brushes work pretty well also. Don't forget to lube it afterward.
__________________ 04 ZX-6R 636 - Full Akra EVO, Ohlins, Traxxion forks, Scotts Damper, PC III, Vortex FrameSliders
06 ZX-10R - Area P Exhaust, FrameSliders, GiPro
PASportbikes.com facebook page for the PA riders http://www.facebook.com/groups/79317358151/
kerosene works better than WD40. Also great for cleaning your wheels!
-Cody
