Corner speed : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Go Back   KawiForums - Kawasaki Motorcycle Forums > Super Sport > Keep it off the Streets! > Road Racing
Old 06-19-2010, 04:12 PM   #1 (permalink)
grimreaper's Avatar
grimreaper has at least 50 rep pointsgrimreaper has at least 50 rep pointsgrimreaper has at least 50 rep points
Default Corner speed
Hi. How do you guys determine the maximum speed around a turn that the bike can handle withough wiping out? I believe people put their knee down to judge how far their bike leans. However, one can put his knee down further then some other rider. Please explain how this works. Thanks.
grimreaper is offline   Reply With Quote
Old 06-19-2010, 04:54 PM   #2 (permalink)
PWS
PWS's Avatar
PWS has at least 10 rep points
It boils down to how big your balls are...the faster you go the more you have to lean. Your brain decides how much is enough...you have to make your brain except the speed and lean so it will let you do it. Obviously there's a point of no return, with good tires you can probably lean it over till your knee rests against the bike{assuming no off camber}.
PWS is offline   Reply With Quote
Old 06-19-2010, 08:43 PM   #3 (permalink)
ghost6_9 has at least 3000 rep pointsghost6_9 has at least 3000 rep pointsghost6_9 has at least 3000 rep pointsghost6_9 has at least 3000 rep pointsghost6_9 has at least 3000 rep pointsghost6_9 has at least 3000 rep pointsghost6_9 has at least 3000 rep pointsghost6_9 has at least 3000 rep pointsghost6_9 has at least 3000 rep pointsghost6_9 has at least 3000 rep pointsghost6_9 has at least 3000 rep points
Yep that's exactly it. Gotta figure out what your comfort level is, and find out how much you can push your tires and chassis.
2000 ZX-6R,fully race prep'd
S.O.A.R. Racing, Lost Era Lightweight
ghost6_9 is offline   Reply With Quote
Old 06-19-2010, 09:50 PM   #4 (permalink)
stingray has at least 500 rep pointsstingray has at least 500 rep pointsstingray has at least 500 rep pointsstingray has at least 500 rep pointsstingray has at least 500 rep pointsstingray has at least 500 rep pointsstingray has at least 500 rep points
trial and error
i doubt most people get to the "maximum" speed of the turn and/or conditions other than their own personal limit of how fast they think they can go through it.
what is maximum to you or me is going slow to those like spies
former AFM #282
stingray is offline   Reply With Quote
Old 06-19-2010, 11:27 PM   #5 (permalink)
S3aturnR's Avatar
S3aturnR has between 7,500 and 10,000 rep pointsS3aturnR has between 7,500 and 10,000 rep pointsS3aturnR has between 7,500 and 10,000 rep pointsS3aturnR has between 7,500 and 10,000 rep pointsS3aturnR has between 7,500 and 10,000 rep pointsS3aturnR has between 7,500 and 10,000 rep pointsS3aturnR has between 7,500 and 10,000 rep pointsS3aturnR has between 7,500 and 10,000 rep pointsS3aturnR has between 7,500 and 10,000 rep pointsS3aturnR has between 7,500 and 10,000 rep pointsS3aturnR has between 7,500 and 10,000 rep points
generally, i just keep riding faster and faster thru the same corner until i can feel the tires slide. if they slide too much, push your knee down harder and you can save a lowside. don't try this on the street, tho...
s3aturnr
1998 zx9r (sold)
2008 zx6r vivid yellow (gone, but not forgotten)
2009 yami r6 orange
S3aturnR is offline   Reply With Quote
Old 06-19-2010, 11:42 PM   #6 (permalink)
DeaninLBC has at least 250 rep pointsDeaninLBC has at least 250 rep pointsDeaninLBC has at least 250 rep pointsDeaninLBC has at least 250 rep points
I agree with PWS and ghost,
Your brain is the determining factor. The pros are using DOT tires and many of them pin their knees against the bike and some drag their elbows. I'd suggest working that out at the track, get videos of yourself and when your brain is ready to do it in a canyon then your there.
I can do it at the track but am always leary of the canyons, "dirt, oil, cops, cars and other riders".
Go to the track or a isolated rough surface parking lot.
DeaninLBC is offline   Reply With Quote
Old 06-19-2010, 11:52 PM   #7 (permalink)
MODERATOR
hoser's Avatar
hoser has at least 80,000 rep pointshoser has at least 80,000 rep pointshoser has at least 80,000 rep pointshoser has at least 80,000 rep pointshoser has at least 80,000 rep pointshoser has at least 80,000 rep pointshoser has at least 80,000 rep pointshoser has at least 80,000 rep pointshoser has at least 80,000 rep pointshoser has at least 80,000 rep pointshoser has at least 80,000 rep points
as far as how far your knee goes out, trial and error in adjusting your form. ideally when your knee touches you know you are at or near max lean.
hoser is offline   Reply With Quote
Old 06-20-2010, 01:33 AM   #8 (permalink)
cromer611's Avatar
cromer611 has at least 2000 rep pointscromer611 has at least 2000 rep pointscromer611 has at least 2000 rep pointscromer611 has at least 2000 rep pointscromer611 has at least 2000 rep pointscromer611 has at least 2000 rep pointscromer611 has at least 2000 rep pointscromer611 has at least 2000 rep pointscromer611 has at least 2000 rep pointscromer611 has at least 2000 rep pointscromer611 has at least 2000 rep points
not true, ive seen people hang so far off their bikes and they have their upper body over the tank with butts hangin way off, so crossed up and the bike only has 20 percent lean angle. just trying to get their knee down, the whole time the bike is upset because of horrible body position.
you want to stay parallel with your bike and use your knee/toe sliders to judge lean angle. As your knee touches the ground, pick your knee back up and lean the bike more until your knee touches again. with more lean angle produces more corner speed. with more corner speed and lean angle increases the risk of losing traction so be careful
im no pro but by just improving my body position ive been able to drop a second early in the season. I still have stuff i need to improve on, like pointing my inside elbow and getting my butt off the bike another inch.
MRA 2010 Race Results
MRA 2009 Race Results
2008 Rookie of the Year
2009 Novice GTU/GTO Champ
2009 Amateur GTU/GTO Champ
cromer611 is offline   Reply With Quote
Old 06-20-2010, 01:46 AM   #9 (permalink)
MODERATOR
hoser's Avatar
thats why i said ideally...lol
Old 06-20-2010, 10:29 AM   #10 (permalink)
Limegreenninja has between 5,000 and 7,500 rep pointsLimegreenninja has between 5,000 and 7,500 rep pointsLimegreenninja has between 5,000 and 7,500 rep pointsLimegreenninja has between 5,000 and 7,500 rep pointsLimegreenninja has between 5,000 and 7,500 rep pointsLimegreenninja has between 5,000 and 7,500 rep pointsLimegreenninja has between 5,000 and 7,500 rep pointsLimegreenninja has between 5,000 and 7,500 rep pointsLimegreenninja has between 5,000 and 7,500 rep pointsLimegreenninja has between 5,000 and 7,500 rep pointsLimegreenninja has between 5,000 and 7,500 rep points
I watched a guy exceed his limit a few weeks ago. He wasn't going to make the inside of the bridge gaurd rail. He stood it up mid corner and opted for the creek instead. No scratches but the 2009 CBR600 was banged up.
Limegreenninja is offline   Reply With Quote
