My First "Wheelies?" Tips? : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Go Back   KawiForums - Kawasaki Motorcycle Forums > Super Sport > Keep it off the Streets! > Stunter's Corner
Old 09-10-2012, 09:59 PM   #1 (permalink)
STiEX's Avatar
STiEX has at least 2000 rep pointsSTiEX has at least 2000 rep pointsSTiEX has at least 2000 rep pointsSTiEX has at least 2000 rep pointsSTiEX has at least 2000 rep pointsSTiEX has at least 2000 rep pointsSTiEX has at least 2000 rep pointsSTiEX has at least 2000 rep pointsSTiEX has at least 2000 rep pointsSTiEX has at least 2000 rep pointsSTiEX has at least 2000 rep points
Default My First "Wheelies?" Tips?
Hey y'all. I've been riding for around 2 years, and have never wheelie'd outside the occasional accidental one. Well, today I actually went out and tried to wheelie. I was wondering if y'all would check out the video, then maybe throw some tips and pointers my way? I appreciate it.
STiEX is offline   Reply With Quote
Old 09-10-2012, 10:06 PM   #2 (permalink)
ZX6R>CBR's Avatar
Do you know what rpms you were clutching it up to?
In the same boat as you, I don't normally do wheelies but I've been popping a couple power wheelies up in first gear. For shits and gigs
ZX6R>CBR is online now   Reply With Quote
Old 09-10-2012, 10:24 PM   #3 (permalink)
STiEX's Avatar
I do not, I was more focused on looking on the road than my RPMs. I found that just getting on it like I"m going to accelerate in first gear then blipping the clutch really got it to come up, but it felt a little sketchy.
Old 09-10-2012, 10:31 PM   #4 (permalink)
ZX6R>CBR's Avatar
Yeah man i know what you mean, plus you have to be concentrating on keeping the bike in one piece, rather than exact rpms. What I've been doing is going in first about 30-40ish right where it gets pretty torquey (8-9k id say) and then closing the throttle and snapping it open quickly. You just have to watch out not to give it too much and loop it over
Old 09-10-2012, 11:46 PM   #5 (permalink)
STiEX's Avatar
Yeah, I'm not gonna try power-wheelies like that. That just seems really sketchy, I like the more control with the clutch-ups.
Old 09-19-2012, 04:27 PM   #6 (permalink)
Fiveoh's Avatar
Fiveoh has at least 500 rep pointsFiveoh has at least 500 rep pointsFiveoh has at least 500 rep pointsFiveoh has at least 500 rep pointsFiveoh has at least 500 rep pointsFiveoh has at least 500 rep points
I am also practicing wheelie , its hard !!! I am only riding for 4 month and its harder than expected , i can now do small standup wheelie ( left foot on rear peg) and seat down i can roll it till rev limiter but thats about it, i suppose iam real close to bp ,i started practicing by rolling in second at about 8-9000 rpm and then clutch up , now my clutching action is a little better so i can do it at about 5-6000 rpm , use one finger.
that what worked for me !
Fiveoh is offline   Reply With Quote
Old 09-20-2012, 09:35 PM   #7 (permalink)
StuntBikeJake's Avatar
StuntBikeJake has at least 500 rep pointsStuntBikeJake has at least 500 rep pointsStuntBikeJake has at least 500 rep pointsStuntBikeJake has at least 500 rep pointsStuntBikeJake has at least 500 rep pointsStuntBikeJake has at least 500 rep pointsStuntBikeJake has at least 500 rep pointsStuntBikeJake has at least 500 rep points
Video is private....... power wheelies will get you hurt btw... also not knowing the correct methods to save a wheelie will get you hurt even worse...
StuntBikeJake is offline   Reply With Quote
Old 11-06-2012, 04:28 PM   #8 (permalink)
GenPatton's Avatar
GenPatton has between 10,000 and 20,000 rep pointsGenPatton has between 10,000 and 20,000 rep pointsGenPatton has between 10,000 and 20,000 rep pointsGenPatton has between 10,000 and 20,000 rep pointsGenPatton has between 10,000 and 20,000 rep pointsGenPatton has between 10,000 and 20,000 rep pointsGenPatton has between 10,000 and 20,000 rep pointsGenPatton has between 10,000 and 20,000 rep pointsGenPatton has between 10,000 and 20,000 rep pointsGenPatton has between 10,000 and 20,000 rep pointsGenPatton has between 10,000 and 20,000 rep points
Send a message via AIM to GenPatton
My opinion ...
The roads you were trying the wheelies on didn't seem to have long straights. If there is a straight road in front of you, you'll feel more comfortable to actually get it up more rather than just off the ground. If you know a turn is coming up, your body will resist you twisting the throttle a little more and go higher.
So I'd say practice on long straight empty roads if you can't find an empty lot.
Like Fiveoh said, hopefully you're using only 1 finger to clutch it up. Don't be so tense on the bars, and make sure you aren't leaning forward.
GenPatton is offline   Reply With Quote
Old 11-09-2012, 10:36 PM   #9 (permalink)
HULK's Avatar
HULK has between 7,500 and 10,000 rep pointsHULK has between 7,500 and 10,000 rep pointsHULK has between 7,500 and 10,000 rep pointsHULK has between 7,500 and 10,000 rep pointsHULK has between 7,500 and 10,000 rep pointsHULK has between 7,500 and 10,000 rep pointsHULK has between 7,500 and 10,000 rep pointsHULK has between 7,500 and 10,000 rep pointsHULK has between 7,500 and 10,000 rep pointsHULK has between 7,500 and 10,000 rep pointsHULK has between 7,500 and 10,000 rep points
Send a message via AIM to HULK
Cover the rear brake.. Clutching around 8-9k in 1st should start getting you off the ground. I've been slowly working on mine but with the change in weather here that's come to a halt.
HULK is offline   Reply With Quote
