Old 07-02-2009, 08:54 PM   #221 (permalink)
Tough-Guy's Avatar
Tough-Guy has between 10,000 and 20,000 rep pointsTough-Guy has between 10,000 and 20,000 rep pointsTough-Guy has between 10,000 and 20,000 rep pointsTough-Guy has between 10,000 and 20,000 rep pointsTough-Guy has between 10,000 and 20,000 rep pointsTough-Guy has between 10,000 and 20,000 rep pointsTough-Guy has between 10,000 and 20,000 rep pointsTough-Guy has between 10,000 and 20,000 rep pointsTough-Guy has between 10,000 and 20,000 rep pointsTough-Guy has between 10,000 and 20,000 rep pointsTough-Guy has between 10,000 and 20,000 rep points
Thou shall recieve no tech from I, foul Sirs.
- I told you not to fuck with K-TRIK because it is watching you and knows all. But NNNOOOOOO, you assholes didn't want to listen.
Tough-Guy is offline   Reply With Quote
Old 07-02-2009, 09:14 PM   #222 (permalink)
Mfromphilly1's Avatar
Mfromphilly1 has at least 3000 rep pointsMfromphilly1 has at least 3000 rep pointsMfromphilly1 has at least 3000 rep pointsMfromphilly1 has at least 3000 rep pointsMfromphilly1 has at least 3000 rep pointsMfromphilly1 has at least 3000 rep pointsMfromphilly1 has at least 3000 rep pointsMfromphilly1 has at least 3000 rep pointsMfromphilly1 has at least 3000 rep pointsMfromphilly1 has at least 3000 rep pointsMfromphilly1 has at least 3000 rep points
Send a message via AIM to Mfromphilly1
any switched power wire.. but be aware of how much power is actually pulled on it before splicing.. if the wire's got a 10 amp load on it, don't put the fan load on it as well.. you'll either pop a fuse or fry the wire. there should be an accessory lead fused at 10 amps all by itself under the seat near the battery.. not sure on your bike for sure, but i know on most kawis they have em.. mind you a motor load pulls 8 times at start-up as it does when running at full load. a 4 amp load when running will spike (LRA or locked-rotor amps) can pull as much as 30 amps or more deopending on the winding type and all..
the hot side of the horn button or similar electrical system would be ideal.
good luck, and thanks t-g for letting me steal the limelight.
This is why I come to this site all the time, the guys (and girls) are always willing to help and they always have answers, Thanks Whitey and TG
"Be polite, be professional, but have a plan to kill everybody you meet." General JAMES N. MATTIS, USMC
Mfromphilly1 is offline   Reply With Quote
Old 07-02-2009, 09:20 PM   #223 (permalink)
wildacex187's Avatar
wildacex187 has at least 1000 rep pointswildacex187 has at least 1000 rep pointswildacex187 has at least 1000 rep pointswildacex187 has at least 1000 rep pointswildacex187 has at least 1000 rep pointswildacex187 has at least 1000 rep pointswildacex187 has at least 1000 rep pointswildacex187 has at least 1000 rep pointswildacex187 has at least 1000 rep pointswildacex187 has at least 1000 rep points
Send a message via AIM to wildacex187
Originally Posted by Tough-Guy View Post
Some how I doubt changing plugs is the reason you are experiencing after-fire. I suspect it has something to do with the Akropovich pipe and a bad tune/lack of fuel management. Unless of course you put in different plugs not recommended for the bike.
the plugs i put in had the same number plus an H at the end. i dont have a cat anymore so i thought it was that. the flames are cool but i know its running rich. its a little hard to start at times (takes more cranking than usual). could it be a vac hose?
zx10r
wildacex187 is offline   Reply With Quote
Old 07-02-2009, 10:57 PM   #224 (permalink)
Tough-Guy's Avatar
Old 07-02-2009, 10:59 PM   #225 (permalink)
whitehendrix's Avatar
Location: Wilmington, Nc.. trying not to crash any more
TG!! good to see ya homey.
and ya.. lean is mean..
leeeaaann is meeaaan. wipes ring out wit a quickness.
▲shuttin down noob "techs" one post at a time▲
Need A "How To"?-USE THIS MOTHERFUCKING LINK!!!!! http://www.kawiforums.com/how-tos-fa...avigation.html
Sept09 B.O.T.M. winner avatar not under my control...
whitehendrix is online now   Reply With Quote
Old 07-02-2009, 11:41 PM   #226 (permalink)
lean makes it shoot fire? i thought when fire came out exhaust it was from unburnt fuel igniting in the exhaust? i'll try running a map off the dynojet website and see if that helps. thanx
zx10r
Old 07-02-2009, 11:51 PM   #227 (permalink)
any abnormal running condition renders abnormal shit like that..lol
it deals as well with EGT's reaching a staggering number. EGT (exhaust gas temperature) operates on a bellcurve with respect to AFR.lets say you're at 1500*F.. that can be lean OR rich. there comes a point to where the peak efficient EGT is exceeded with a lean or rich condition.. goes the other way too.. you'll see them drop off due to slobbery rich AFR or stupid lean ones.. both EGT drops are due to lack of combustion efficiency. rich is just simply too much fuel and lean is not enough...
could be a few things at this point.. being i cant see or smell it and TG cant hook up a gas analyzer we're stuck guessing..lol
what kinda throttle response and all are you getting? whats the exhaust look like under load? gray? black? can't see it at all? bike runnin hot? stumbles when hot/cold?
Old 07-03-2009, 01:06 AM   #228 (permalink)
stationary i could rev the bike to 10k rpm or so and let go of the throttle. the first few times it wont do it but after 3 or 4 times flames will shoot out. bike has been running same as always. tomorrow i'll put back the fairings and take her for a ride and see if it does it while revving but i dont think it will its when the revs come down that it does it.
also theres no smoke or anything coming out. first couple of revs u'll hear the popping then a few more flames. hope that makes sense lol
zx10r
Old 07-03-2009, 01:17 AM   #229 (permalink)
sounds like you're simply loading the cylinders... the bike can't tell whether it's under load or not.. therefore it dumps a preprogrammed amount of fuel in each cylinder anticipating a load to be placed. when no load is present, less fuel is used, resulting in "loading".. it's on a more moinor scale than race motors or top-fuel dragsters and all, but nonetheless, thats what it sounds like to me.. you're just kinda wasting fuel at that point..lol
lean will pop like a motherfucker. had a CFR 450 i just fixed up and tuned that did that shit. threw 1 foot flames and sounded like fuckin fireworks goin off in the shop..lol thats a big bore too, alot of air and fuel goin in and out fast. got the shit dialed in and it was dead quiet on decel and accel and no-load rev, except for the loud ass FMF pipe.. that bike is a goddamn monster too..lol 5th gear roll-on wheelies FTW.
Old 07-03-2009, 02:03 AM   #230 (permalink)
so if it doesnt do it the first time i rev it up and let it rev down then its just "loading" like u said? thats a relief. i dont mind about the fuel. bike has been down for over a month and im itching to get here out. its 2am and im going into my friends shop at 8 to finish everything by 1pm, go home and shower then go to work till 11pm JUST cuz i want my bike back
zx10r
