1: Anyone know how to get in touch with this guy? You go on the website (doublezracing.com) and try to click "contact" and it doesn't work.
2: I know he makes an insert for the '08-'09 ZX10R...I assume that should be the same for my '09 ZX6R?
3: Has anyone had issues with the throttle cable adjustment after cutting the lock rings off? As in, does it lose it's adjustment often w/o the lock rings?
Originally Posted by helo-pilot
just do the zip tie mod. does the same thing for about 3 cents.
I've tried that zip tie mod thing about 3x's and each time I can't get the epoxy to bond to whatever the hell the stock plastic throttle insert thing is made of. I gave up on it! If I'm so inclined I'll either attempt the pvc route or just break down and get the rifleman one.
Yeah, I've tried a few different adhesives with no luck either
__________________ "I always feel a little better after a ride" ~49k miles so far
i've zip tied every bike i've owned (minus the gsxr1k because the r1 tube was easier) i use super glue & i also heat the zip tie to help it form a bit better, then glue & then throw a thick rubberband over it till it cures
