how to you fix your throttle sticking??? - KawiForums - Kawasaki Motorcycle Forums
post #1 of 9 (permalink) Old 04-03-2010, 12:42 PM Thread Starter
bigrallymeats's Avatar
Send a message via AIM to bigrallymeats
so my throttle return is not working and idk how to fix it.. the grip isn't rubbing or anything like that so i'm confused. bought the bike used and it's been sticking ever since. do i just spray some lube on my cable or something or what?
bigrallymeats is offline
post #2 of 9 (permalink) Old 04-03-2010, 01:25 PM
MODERATOR
hoser's Avatar
prop the tank and check the routing of the lines, they can bind if routed wrong. being used it could probably stand a little look-see anyhow...
hoser is offline
post #3 of 9 (permalink) Old 04-03-2010, 01:26 PM
MODERATOR
hoser's Avatar
hoser is offline
post #4 of 9 (permalink) Old 04-03-2010, 01:28 PM
ZX6RRNewbie's Avatar
I recommend you follow your throttle cable and check everything it's hooked up to starting with the grip. Make sure everything is free and all springs are in working order. You should be able to find the culprit.
You already found that the grip is not the problem so next check the cable it could be broken or frayed inside keeping it from returning, if the cable is OK next check the throttle bodies.
from BEAUTIFUL AUSTIN TEXAS
2006 Lime Green ZX6R
ZX6RRNewbie is offline
post #5 of 9 (permalink) Old 04-03-2010, 04:05 PM
Sev
The Indifference Engine
Sev's Avatar
Loosen off the tension on the return cable.
Make sure the grip isn't rubbing on the bar end.
Sev is offline
post #6 of 9 (permalink) Old 04-03-2010, 05:26 PM
Yuriy's Avatar
Check the lines for kinks or bends (both throttle cables). And lube your cables. I had a similar problem with my throttle not being as smooth as I'd like (along with the clutch) so I checked the routing and lubed the cables. It makes a big difference.
I wrote it up here, if you want to get an idea of how to do it.
Smooth Cables and Better Controls Live, Learn, and Ride
'01 ZX-6R - Bumble Bee Yellow with DDM Tuning HID Kit
Yuriy is offline
post #7 of 9 (permalink) Old 04-03-2010, 09:52 PM
Send a message via AIM to AceTech918 Send a message via MSN to AceTech918 Send a message via Yahoo to AceTech918
take the bike to your local toyota dealer they should be good at fixin sticking throttles by now. SERIOUSLY
AceTech918 is offline
post #8 of 9 (permalink) Old 04-04-2010, 01:32 AM
Where is hoser??
hoser is a cable-luber.
--Cobra
1969 A7 - Pagyu | 2003 Gas Gas - Dirtstar | 2005 Pitbike | 1973 Bicycle | 2000 VF
Stuff for sale. Click me!! Stuff for sale.
Cobra is offline
post #9 of 9 (permalink) Old 04-05-2010, 04:29 PM Thread Starter
cool.. i'm going to try this out.
