Clutch cable freeplay - KawiForums - Kawasaki Motorcycle Forums
post #1 of 14 (permalink) Old 04-17-2010, 01:31 AM Thread Starter
sprtonyy's Avatar
Hey guys, I've been looking around on how to adjust the clutch and I've found quite a bunch of useful resources, but I still can't figure out how to use the adjuster, i've tried to twist it clockwise but yeah... Would adjusting my clutch fix my "slipping clutch" problem? (I'm starting to feel it so I want to fix it before it gets worst. :S
sprtonyy is offline
post #2 of 14 (permalink) Old 04-17-2010, 04:23 AM
zx6-r's Avatar
you can adjust at the lever or down at the case. as far as the slipping goes how many miles ya got? might be worn out. find your friction zone and and just go from there. if you got the cable to tight the clutch might not be released all the way and give you that slipping feel.
zx6-r is offline
post #3 of 14 (permalink) Old 04-17-2010, 04:41 AM
VeX
I ♥ Cute Cats!
VeX's Avatar
For the 250 there's supposed to be a "free play" of 2-3mm (ideally just a little bit of play in the clutch lever). If you're sitting on the bike and squeeze the clutch you can see the lever move on the transmission on the right side of the engine.
If you have the clutch adjuster at the lever all of the way out or in and still need more adjustment, then you have to adjust it where it connects to the transmission. Even though with most things want to eliminate play, you want to make sure there is a LITTLE bit of movement in the lever before you see the lever move down on the transmission.
VeX is offline
post #4 of 14 (permalink) Old 04-17-2010, 05:10 AM Thread Starter
sprtonyy's Avatar
I have about 9500kms on it so im not quite sure if my plates are worn out, as for the adjusting i can see where youre coming from, but in a sense its sorta not making sense (to me cos im a beginner lol)... I understand that supposedly im meant to have 2-3mm but I cant create that free play by just using my "adjuster" am I doing something wrong :s
sprtonyy is offline
post #5 of 14 (permalink) Old 04-17-2010, 05:16 AM
VeX
I ♥ Cute Cats!
VeX's Avatar
So if you loosen the adjuster (turn it in clock-wise all of the way) the lever doesn't have ANY slack in it?
VeX is offline
post #6 of 14 (permalink) Old 04-17-2010, 05:41 AM
Send a message via AIM to saadatorama
the clutch cable should not have any effect on "slipping" clutch unless it's frayed. i think it's time for you to get a new clutch.
[2007 zx6r :: jumper mod :: -1/+1 renthal sprocket :: 520 chain conversion :: "cf" puig windscreen :: pciii usb :: pinebox headers :: yoshimura rs5 can :: k&n air filter :: CRG gold standard levers :: Michellin Pilot Power front and rear :: ... and the modding continues]
saadatorama is offline
post #7 of 14 (permalink) Old 04-17-2010, 07:57 AM Thread Starter
sprtonyy's Avatar
yup that is correct
I see, thanks for the heads up
sprtonyy is offline
post #8 of 14 (permalink) Old 04-17-2010, 11:50 AM
Powerhungry
nevada's Avatar
if its too tight, it'll allow the to clutch slip.
proper clutch cable adjustment is important.
ERIN
nevada is offline
post #9 of 14 (permalink) Old 04-17-2010, 12:02 PM
goingtoscotland's Avatar
the reason you have free play in the clutch cable is two fold.
1. so when you turn the bars it doesn't disengage the clutch unintentionally(same reason the throttle cables have freeplay in them)
2. so the clutch fully engages. if the cable is constantly pulling the pressure plate out, the clutch will always slip.
if you have run out of adjustment at the lever you'll have to adjust it at the clutch end.(the clutch cable does not connect to the transmission). when you turn the adjuster clockwise you're loosening the cable putting more free play into it. when you turn it counterclockwise you're giving it less play.
the free play on most bikes is around 3mm. that's the lever moving away from the perch 3mm before clutch disengagement starts. 3mm is not at the end of the lever.
goingtoscotland is offline
post #10 of 14 (permalink) Old 04-18-2010, 02:27 AM Thread Starter
sprtonyy's Avatar
oh i sorta get it now, thanks! Could you elaborate on "if you have run out of adjustment at the lever you'll have to adjust it at the clutch end" and "3mm is not at the end of the lever" =\
sprtonyy is offline
