Cheap 2 stroke oil vs expensive brand name. Any difference. - KawiForums - Kawasaki Motorcycle Forums
post #1 of 10 (permalink) Old 08-27-2010, 12:24 AM Thread Starter
I tried searching for this before posting, would have imagined it would have been asked 100 times, but found nothing.
Is there really any difference between 2 stroke oils? Are the fancy expensive brand names actually better, or is it just hype and/or placebo effect?
I have a '93 kx250, that I have had for many years, I've used the kawisaki 2 stroke oil, castor 929, yamalube, etc 2 stroke oils. Back when they costed $6 for a quart I thought it was a ripoff, but dealt with it. Nowadays the nearest bike shop wants over $12 a quart for 2 stroke oil. Ridiculous! I bought it since I was in a pinch last time, but I never want to pay that price ever again for a quart of oil. I've seen 2 stroke oil at wal-mart for like $2.50.
Is there actually any legitimate difference between genaric 2 stroke oil, and all the fancy racing bike oils? Or is it all the same stuff with different marketing?
It can't be that much different right? I mean all it does is provides a quick moment of lubrication in its brief life before burning up.
Would some genaric 2 stroke oil be just fine for my bike, or a bad idea? It would be one thing if I was racing or something and needed every little .05% extra power, but I only ride for fun, mostly trails, splashing in the mud, hill climbs, jumps, etc. Just general all around riding, on an old '93 kx250. As long as I'm not fowling plugs all the time or running poorly I'd be happy.
carl1864 is offline
post #2 of 10 (permalink) Old 08-27-2010, 01:05 AM
weebel's Avatar
When it comes to the better brands, your pretty safe no matter what, but when you get into the really cheap crap, stay away from that. A lot of that "value oil" is cheap shit.
weebel is offline
post #3 of 10 (permalink) Old 08-27-2010, 02:29 AM
I buy castor 927 at ~$20/qt. Mixing at 32:1 costs you $2.50 worth of oil per gallon. So a good "expensive" oil is still cheaper than the gas you are mixing it with. Would you use water instead of gas because gas is horribly expensive?
That brief moment is an opportunity for your piston to burn up, or the oil. I'd choose the oil.
If you can't tell already, I'm a big fan of good oil. My dirtbike (yz250) is stock, gets only castor but could probably survive on less. My moped is modded from 49cc to 80cc and I'd rather push it home than put in cheap oil. It's not really about gaining/losing power now, but preserving your cylinder/piston so you don't have to buy a new one.
808BMW is offline
post #4 of 10 (permalink) Old 08-27-2010, 10:26 AM
ross93's Avatar
$20 wholly hell!!
i use valvoline in my yamahoppers (mopeds). i dont like the oils that burn clear cause its got a oil pump. there from the 80s and still goin strong
just run kawi 2 stroke oil if they make it, if not run yamalube 2r or motul. thats gunna be plenty good
03 zx6rr jardine k&n pcIII hyperpro crg ivans
ross93 is offline
post #5 of 10 (permalink) Old 08-27-2010, 01:15 PM
The Yamalube is good stuff. Ran it in all my bikes. Stay away from the cheap stuff. Your silencer and rings will thank you. I am using some pre mix that my buddies use on their shifter carts right now. I will try and find the name.
dmigod is offline
post #6 of 10 (permalink) Old 08-27-2010, 01:21 PM
Found It.
Maxima 927 Castor $8.99 for 16OZ I like this even better than the yamalube.
dmigod is offline
post #7 of 10 (permalink) Old 08-27-2010, 07:40 PM
ratherberiding
joonyaboy's Avatar
Send a message via Yahoo to joonyaboy
Amsoil Dominator is awesome
"I always feel a little better after a ride" ~52k miles so far
joonyaboy is offline
post #8 of 10 (permalink) Old 08-27-2010, 07:47 PM
whitehendrix's Avatar
speaking from personal experience building my own kx and others for race use, they tend to carbon up pretty bad in the power valve chambers so if you can find an oil that creates less carbon deposits, thats the ticket. you'll go a bit more between top-end rebuilds as well
you figure the lubricity and sheer strength is gonna be different under fire than it will be under the load of bearing and gear surfaces and since the crank pocket is sealed, whatever oil you mix will never see the bearings or gears..
i'd rather run good stuff than NOT, but the cheap stuff will always get ya by. i've had customers who explicitly use the cheap shit with no problems too. it's all in the riding style and maintenance as well.
gonna beat on it? you can probably get away with a cheaper oil.. gonna woods ride and put around? you'll want something less prone to carbonization since you're at or near idle longer.
►Sept09 B.O.T.M. winner◄
Need A "How To"? CLICK ME!!
whitehendrix is offline
post #9 of 10 (permalink) Old 08-28-2010, 02:18 PM Thread Starter
Thanks for the answers. Guess I'll just stick with the yamalube and castor 927 stuff or whatever, but I'll just have to buy it out of town from a different bike store.
My local bike store, Renton Motorcycles RMC sucks, and I think they rip you off on purpose. They are one of the biggest around, yet they only have one single cashier in the entire parts, oil, apparel, gear, etc department, never seen more than one (and there is only one booth). And they never put the price on any of the oils. You can't ask how much it costs either since there is always a huge line since there is only one cashier. So you basically have to grab the oil and stuff, wait for like 10-30 minutes to checkout, and then get slapped in the face with the suprise price like 12.95 or something for a quart of yamalube.
And by that time your probably running behind from standing in line so long, don't have time to go 1-2 cities over to the next nearest bike store, and need the oil, so you just buy it and walk out of the store in shame because of how bad you've just been ripped off. I really think they set it up that way on purpose.
carl1864 is offline
post #10 of 10 (permalink) Old 08-28-2010, 02:24 PM
scottynoface's Avatar
Ditto. My RM loves the stuff, or at least did before I cracked a water jacket.
2003 ZX636R - Now in pieces
2000 RM 125 - Waiting to tear down again
scottynoface is offline
