Spray Paint - KawiForums - Kawasaki Motorcycle Forums
post #1 of 16 (permalink) Old 04-28-2011, 11:44 AM Thread Starter
Send a message via Skype™ to EddyTing
Spray Paint
Hi, anyone can advice me on how to spray paint my bike in 2 different colors? And also what are the secrets to get the super shining long lasting finishing?
EddyTing is offline
post #2 of 16 (permalink) Old 04-28-2011, 12:02 PM
ddella22's Avatar
masking tape and clear coat, and lots of sanding
ddella22 is offline
post #3 of 16 (permalink) Old 04-28-2011, 01:12 PM
SuperCheese88's Avatar
Sand smooth, primer, lay darker color, 2 days for it to dry, lay tape, spray 2nd color, follow can dry times, wet sand 1000 grit, clear.
SuperCheese88 is offline
post #4 of 16 (permalink) Old 04-28-2011, 01:34 PM
Opus's Avatar
Orange and green?
Opus is offline
post #5 of 16 (permalink) Old 04-28-2011, 05:18 PM
Yep. Wanted something different. Think I covered "different" pretty well.
post #6 of 16 (permalink) Old 04-28-2011, 11:07 PM
ShamRock229's Avatar
Originally Posted by Opus View Post
Orange and green?
As an Irishman, I can dig it.
You got a pic of it on the bike?
Something I have been wondering is what brand of spray paint is the best for painting plastics? I've heard good things about Krylon. Any others?
2009 Green 650r - SOLD!
2009 ZX6R ME
Originally Posted by cookiebug79 View Post
The jam nuts on my linkage were tight so I don't think it loosened up.
ShamRock229 is offline
post #7 of 16 (permalink) Old 04-28-2011, 11:40 PM
Overwhelming Splendidery
slev's Avatar
I didn't sand my panels at all... just washed them up, 2 coats of primer, 4 coats of black and 6 coats of clear.
Used Duplicolor Acrylic Enamel.
15 mins between primer coats. Then 15 mins between black coats... waited 2 hours then did my clearcoats 15 mins apart.
.: Titanium 2005 636 .:. Orange 2009 ZX6R (stolen) .:. Black 2015 Z1000 :.
slev is offline
post #8 of 16 (permalink) Old 04-28-2011, 11:43 PM
That Fighter Guy
LarryJ's Avatar
Sand smooth, put a couple layers of primer down, 15-20 minutes between coats, let primer dry, wet sand to a smooth finish.
Lay down one color, do 4-6 coats, 15-20 minutes between coats, let fully cure (it'll be on the can how long). Mask off the area you just painted (one strip of tape and thick paper, not tape the whole thing) and anywhere else you don't want overspray. Reapeat above process (4-6 coats, let cure fully). Remove all tape and paper. I like to use 2000 grit paper and a bucket of water. Dip the paper, sand the surface, and keep dipping the paper to keep it wet. When it's nice and smooth all over, then you're done. You'll likely still be able to feel the transition between the colors, but don't sweat it. Clean and dry the surface thoroughly. Lay down 2-4 clear coats, 15-20 minutes between coats, then let cure fully. Wet sand with 2000 grit till smooth, then buff with buffing compound and a soft rag until it's super smooth. Lay down wax and call it done.
Good luck. Practice makes perfect.
LarryJ is offline
post #9 of 16 (permalink) Old 04-29-2011, 12:06 AM
rodey1825's Avatar
Krylon is one of the best spray paints for the value. I always use Krylon with any project I do and it seems to be exceptional with plastics.
07 Kawasaki ZX6R - Two Bros Race Exhaust and Fender Eliminator, PCIII, Vortex Shorty Levers, Jumper Mod, 520 Chain, Black Hotbodies DB Windscreen, Black Turn Signals, Black Powder Coated Pegs and Heel Guard, Shogun Frame and Swingarm Sliders, Ram Mount for Garmin GPS.
rodey1825 is offline
post #10 of 16 (permalink) Old 04-29-2011, 12:08 AM
That Fighter Guy
LarryJ's Avatar
I like Dupli-color enamels. It's readily available at most auto parts stores (in red, yellow, blue, and black typically) and it goes on really nicely.
LarryJ is offline
