Do You Roll with Nitrogen or Oxygen ? - Page 2 : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Old 11-06-2012, 11:07 AM   #11 (permalink)
The Antistart
Green's Avatar
Originally Posted by exalted512 View Post
I use a 78% nitrogen, 20% oxygen, 2% 'other' hybrid.
-Cody
Lol...yep.
Originally Posted by strat1701 View Post
When I said standard O2, I meant it's the standard air/oxygen we all breathe (yes I know it's a mixture of nitrogen and some other small trace gasses), that can be obtained from the gas station air compressors for .50. I should have been more clear. You'd be very dumb to run pure O2 in anything because if it blows up you're fucked. Pure oxygen is HIGHLY flammable.
Oxygen is not flammable. It is one of the key components to fire, but without another fuel, it will not burn. Fire requires fuel, heat, and O2.
Old 11-06-2012, 12:20 PM   #12 (permalink)
Sev
The Indifference Engine
Sev's Avatar
I fill mine up with helium to reduce weight.
-Cody
I was going to make that joke.
Old 11-06-2012, 12:28 PM   #13 (permalink)
Play with my wand....
strat1701's Avatar
strat1701 has at least 80,000 rep pointsstrat1701 has at least 80,000 rep pointsstrat1701 has at least 80,000 rep pointsstrat1701 has at least 80,000 rep pointsstrat1701 has at least 80,000 rep pointsstrat1701 has at least 80,000 rep pointsstrat1701 has at least 80,000 rep pointsstrat1701 has at least 80,000 rep pointsstrat1701 has at least 80,000 rep pointsstrat1701 has at least 80,000 rep pointsstrat1701 has at least 80,000 rep points
Originally Posted by Green View Post
Lol...yep.
Apollo 1 capsule fire? It had pure O2, spark, flame, ded. After that, they (Nasa) nixed the whole pure O2 environment thing. Do things in a pure O2 environment become MORE flammable than they would normally be? Is that the case? I have heard that about O2 as well.
DAMN YOU! Stop posting that horrendous cunt.
Originally Posted by Cobra View Post
+1 I like the new and harsher strat.
iPost from a real fucking pc not a smartphone
strat1701 is offline   Reply With Quote
Old 11-06-2012, 12:50 PM   #14 (permalink)
The Antistart
Green's Avatar
Essentially, yes. They burn easier because of the added O2.
The O2 in the Apollo fire (as any other fire) was not the fuel.
Think about it...if all you needed was O2 and heat, we wouldn't need gas to run an engine. Take the O2 away and there's no combustion.
Old 11-06-2012, 12:51 PM   #15 (permalink)
av8r-92's Avatar
The oxygen's not burning. The fuel is what's burning. The greater the amount of oxygen, the easier it is for combustion to occur.
-Will
KEEP CALM AND CHIVE ON
"Trust me; I'm a pilot."
Old 11-06-2012, 12:59 PM   #16 (permalink)
av8r-92's Avatar
As for nitrogen, aside from my car coming from the dealer with it, I've never used it in either of my bikes nor my cars.
It seems like it's a bitch to find.
-Will
Old 11-06-2012, 01:05 PM   #17 (permalink)
BP
BP's Avatar
I fill 'em with hydrogen. I wanna look like Ghostrider if my tires blowout.
2005 Raw Ti ZX6R
BP is online now   Reply With Quote
Old 11-07-2012, 06:26 PM   #18 (permalink)
Jeff in Kentucky's Avatar
Our car tires have all nitrogen in them, because we bought the tires at TireDiscounters and they include it for no extra charge. I think the main benefits for street use are that the tires lose pressure slower than with regular air, and the electronic tire pressure sensors inside the tires corrode slower if you plan to keep the car for 20 years.
My motorcycle tires have regular air and the little ceramic balancing beads inside of them. I think the tires lose air slower than with outside balancing weights, because there is ceramic dust generated from the rolling beads that fills tiny air leaks.
Old 11-07-2012, 06:48 PM   #19 (permalink)
Tyler33 has at least 1500 rep pointsTyler33 has at least 1500 rep pointsTyler33 has at least 1500 rep pointsTyler33 has at least 1500 rep pointsTyler33 has at least 1500 rep pointsTyler33 has at least 1500 rep pointsTyler33 has at least 1500 rep pointsTyler33 has at least 1500 rep pointsTyler33 has at least 1500 rep pointsTyler33 has at least 1500 rep pointsTyler33 has at least 1500 rep points
This is why I always add dust to my tires when filling them up.
2005 ZX636 Streetfighter - Sold - Build Thread
Work in progress - 2001 Bandit 1200
09 Fender Adaptor Kits - Fits 03-08 ZX6-R, 04-07 ZX10-R
Tyler33 is online now   Reply With Quote
Old 11-08-2012, 04:26 AM   #20 (permalink)
Just so ya know... That bit extra they charge you to deal with TPMS tires is so that they can buy and install the rebuild kit for the sensor.
As for the second part, well if that's what you think then hopefully it works out for you.
Currently own:
05 Z750S
Have owned:
01 Volusia
