Sprocket chain question : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Old 11-06-2012, 06:01 PM   #1 (permalink)
Camreno's Avatar
Camreno has at least 250 rep pointsCamreno has at least 250 rep pointsCamreno has at least 250 rep pointsCamreno has at least 250 rep points
Default Sprocket chain question
So about a month ago I was on a road trip and my chain broke so took it to a shop down there, wanted a good chain so i could make it back home, one of the ones that you can't take off, some special rivit tool you to put on. now it's time for new sprockets is there a way I can change them without having to get a new chain?
If its too Loud, Your too Old
Camreno is offline   Reply With Quote
Old 11-06-2012, 06:56 PM   #2 (permalink)
Flexxx's Avatar
Flexxx has at least 250 rep pointsFlexxx has at least 250 rep pointsFlexxx has at least 250 rep pointsFlexxx has at least 250 rep points
Loosen the axle, pull the axle out, slide the rear wheel forward then down, and you should be able to take it all the way out.
This is what brings me to the Kawi side...
http://www.r1-forum.com/forums/showthread.php?t=346632
Flexxx is offline   Reply With Quote
Old 11-06-2012, 06:56 PM   #3 (permalink)
Camreno's Avatar
Hmm that might work, thanks!
Old 11-06-2012, 10:36 PM   #4 (permalink)
zvenkruspe's Avatar
It has to work. Otherwise ppl would need new chains with every new tire change
Old 11-07-2012, 12:54 AM   #5 (permalink)
weebel's Avatar
weebel has between 10,000 and 20,000 rep pointsweebel has between 10,000 and 20,000 rep pointsweebel has between 10,000 and 20,000 rep pointsweebel has between 10,000 and 20,000 rep pointsweebel has between 10,000 and 20,000 rep pointsweebel has between 10,000 and 20,000 rep pointsweebel has between 10,000 and 20,000 rep pointsweebel has between 10,000 and 20,000 rep pointsweebel has between 10,000 and 20,000 rep pointsweebel has between 10,000 and 20,000 rep pointsweebel has between 10,000 and 20,000 rep points
WTF really?
You just break the chain and use a new master link assuming the chain is still good. It is recommended that you replace the chain along with a sprocket change but if the chain is still pretty new its not a big deal.
If you can't get it off without breaking the chain. Just grind the master off with a dremel or something (the correct way) and get a clip type master for a couple of bucks that can be put on with hand tools. If you dont have access to said power tool, a chain breaker is going to cost less so just do it the right way if thats the case.
I know you are just trying to save money but if this costs to much then affording proper maintenance on the bike is going to be hard for you. Not trying to be a dick or anything.
But no one removes a wheel in the way that has been mentioned when you take it in for service, thats something you try to do in a rare circumstance at home lol.
weebel is offline   Reply With Quote
Old 11-07-2012, 01:05 AM   #6 (permalink)
lol wut?
TheRussian's Avatar
TheRussian has between 70,000 and 80,000 rep pointsTheRussian has between 70,000 and 80,000 rep pointsTheRussian has between 70,000 and 80,000 rep pointsTheRussian has between 70,000 and 80,000 rep pointsTheRussian has between 70,000 and 80,000 rep pointsTheRussian has between 70,000 and 80,000 rep pointsTheRussian has between 70,000 and 80,000 rep pointsTheRussian has between 70,000 and 80,000 rep pointsTheRussian has between 70,000 and 80,000 rep pointsTheRussian has between 70,000 and 80,000 rep pointsTheRussian has between 70,000 and 80,000 rep points
Send a message via Skype™ to TheRussian
Originally Posted by weebel View Post
WTF really?
All he needs to do is take the wheel off. What are you on about dude?
2004 ZX6RR 2006 350Z
Y U No click this link
TheRussian is offline   Reply With Quote
Old 11-07-2012, 01:31 AM   #7 (permalink)
weebel's Avatar
He is under the false impression that the chain can not be removed. It can.
Old 11-07-2012, 02:01 AM   #8 (permalink)
TimmaethBoy's Avatar
TimmaethBoy has at least 4000 rep pointsTimmaethBoy has at least 4000 rep pointsTimmaethBoy has at least 4000 rep pointsTimmaethBoy has at least 4000 rep pointsTimmaethBoy has at least 4000 rep pointsTimmaethBoy has at least 4000 rep pointsTimmaethBoy has at least 4000 rep pointsTimmaethBoy has at least 4000 rep pointsTimmaethBoy has at least 4000 rep pointsTimmaethBoy has at least 4000 rep pointsTimmaethBoy has at least 4000 rep points
Cocaine's a helluva drug.
I guess he completely looked past the fact that zvenkruspe was making a reference to Flexxx's post. A herpa der.
TimmaethBoy is online now   Reply With Quote
Old 11-07-2012, 03:50 AM   #9 (permalink)
SuperCheese88's Avatar
SuperCheese88 has at least 80,000 rep pointsSuperCheese88 has at least 80,000 rep pointsSuperCheese88 has at least 80,000 rep pointsSuperCheese88 has at least 80,000 rep pointsSuperCheese88 has at least 80,000 rep pointsSuperCheese88 has at least 80,000 rep pointsSuperCheese88 has at least 80,000 rep pointsSuperCheese88 has at least 80,000 rep pointsSuperCheese88 has at least 80,000 rep pointsSuperCheese88 has at least 80,000 rep pointsSuperCheese88 has at least 80,000 rep points
Make sure the new sprockets are the same size or the chain may not fit back on.
WTF really?
You're dense.
Join PWT and waste time with us
http://www.kawiforums.com/nws/202816...oes-vegas.html
SuperCheese88 is offline   Reply With Quote
Old 11-07-2012, 07:21 AM   #10 (permalink)
Flexxx's Avatar
I gave a very SIMPLE way to remove the rear tire/rim to access the sprocket and zvenkruspe was just agreeing. You must've had those shades on in your avatar when you were reading that one...
