Best tool to shave fiberglass fairings? : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Old 12-01-2012, 07:04 PM   #1 (permalink)
Steel's Avatar
Steel has at least 1000 rep pointsSteel has at least 1000 rep pointsSteel has at least 1000 rep pointsSteel has at least 1000 rep pointsSteel has at least 1000 rep pointsSteel has at least 1000 rep pointsSteel has at least 1000 rep pointsSteel has at least 1000 rep points
Default Best tool to shave fiberglass fairings?
I bought some flush mount turn signals for my 04 6rr, but the fairings stick out a little bit in that area for and they won't lay even remotely smooth. The sides are aftermarket fiberglass and I'm wondering what tool would be the best to shave/grind them down in that area.
I'm thinking of just using a semi aggressive file that I've used on metal before, but am somewhat worried about sending a crack through the fairing, anyone have some input?
Steel is online now   Reply With Quote
Old 12-01-2012, 07:20 PM   #2 (permalink)
two6ryder's Avatar
two6ryder has at least 1500 rep pointstwo6ryder has at least 1500 rep pointstwo6ryder has at least 1500 rep pointstwo6ryder has at least 1500 rep pointstwo6ryder has at least 1500 rep pointstwo6ryder has at least 1500 rep pointstwo6ryder has at least 1500 rep pointstwo6ryder has at least 1500 rep pointstwo6ryder has at least 1500 rep pointstwo6ryder has at least 1500 rep pointstwo6ryder has at least 1500 rep points
Orbital sander works great
two6ryder is offline   Reply With Quote
Old 12-01-2012, 07:21 PM   #3 (permalink)
two6ryder's Avatar
Orbital sanders
Old 12-02-2012, 10:55 AM   #4 (permalink)
Ianshort09's Avatar
Ianshort09 has at least 1000 rep pointsIanshort09 has at least 1000 rep pointsIanshort09 has at least 1000 rep pointsIanshort09 has at least 1000 rep pointsIanshort09 has at least 1000 rep pointsIanshort09 has at least 1000 rep pointsIanshort09 has at least 1000 rep pointsIanshort09 has at least 1000 rep pointsIanshort09 has at least 1000 rep points
Orbital sander?
Ianshort09 is offline   Reply With Quote
Old 12-02-2012, 11:56 AM   #5 (permalink)
J-moges has between 7,500 and 10,000 rep pointsJ-moges has between 7,500 and 10,000 rep pointsJ-moges has between 7,500 and 10,000 rep pointsJ-moges has between 7,500 and 10,000 rep pointsJ-moges has between 7,500 and 10,000 rep pointsJ-moges has between 7,500 and 10,000 rep pointsJ-moges has between 7,500 and 10,000 rep pointsJ-moges has between 7,500 and 10,000 rep pointsJ-moges has between 7,500 and 10,000 rep pointsJ-moges has between 7,500 and 10,000 rep pointsJ-moges has between 7,500 and 10,000 rep points
Grab some drum sandpaper. http://www.farmandfleet.com/products...l#.ULuH9obW5C0
Lowes has them, used them on my track plastics, better for small jobs, attach to a drill and just do what you need to.
Originally Posted by FightingFalcon View Post
All I'm saying is that our trannys are designed to handle the load (yea, I just said that)
J-moges is offline   Reply With Quote
Old 12-02-2012, 01:42 PM   #6 (permalink)
sprorchid's Avatar
sprorchid has at least 2000 rep pointssprorchid has at least 2000 rep pointssprorchid has at least 2000 rep pointssprorchid has at least 2000 rep pointssprorchid has at least 2000 rep pointssprorchid has at least 2000 rep pointssprorchid has at least 2000 rep pointssprorchid has at least 2000 rep pointssprorchid has at least 2000 rep pointssprorchid has at least 2000 rep pointssprorchid has at least 2000 rep points
or sand by hand, or file lightly. it'll all work. orbital sander, the entry level ones, $20 at home depot.
sprorchid is offline   Reply With Quote
Old 12-03-2012, 08:49 AM   #7 (permalink)
Dremel is good for small areas, If the fairings are fibreglass be aware that the gelcoat isn't very thick and it's easy to go through it.
