Good Battery? : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Old 12-06-2012, 07:02 PM   #1 (permalink)
TylerD has at least 10 rep points
Exclamation Good Battery?
The battery in my 2009 Kawasaki Ninja 650R died on me just before winter. I need to winterize my bike and get a new battery. Is there a battery that is preferred to use in my bike? Also what all do i need to do to winterize my bike? I just got it in April so im not sure what to do.
TylerD is offline   Reply With Quote
Old 12-06-2012, 07:15 PM   #2 (permalink)
Powerhungry
nevada's Avatar
if you're going to just park it for the winter, wait until spring to replace the battery.
there no sense in buying it, justs to have it sit all winter.
Old 12-06-2012, 07:21 PM   #3 (permalink)
ya i was planning on waiting till spring but i wasnt sure which type of battery to get. idk what those gel batteries are like and which is better.
Old 12-06-2012, 07:35 PM   #4 (permalink)
agg2001's Avatar
agg2001 has at least 4000 rep pointsagg2001 has at least 4000 rep pointsagg2001 has at least 4000 rep pointsagg2001 has at least 4000 rep pointsagg2001 has at least 4000 rep pointsagg2001 has at least 4000 rep pointsagg2001 has at least 4000 rep pointsagg2001 has at least 4000 rep pointsagg2001 has at least 4000 rep pointsagg2001 has at least 4000 rep pointsagg2001 has at least 4000 rep points
get one in the spring, and go shorai. they're MUCH lighter, and have a bullet-proof, no-questions-asked, 2-year warranty on em. worth every penny.
agg2001 is offline   Reply With Quote
Old 12-06-2012, 07:40 PM   #5 (permalink)
alright thank you. Ill have to check them out.
Old 12-07-2012, 01:03 PM   #6 (permalink)
Kawikid72's Avatar
Go to your local cyclegear or bike shop and pick this up, use it every year.
Maxima Fuel Stabilizer 8 Ounces | 900-502 | J&P Cycles
Whore your slut out
Old 12-08-2012, 01:15 AM   #7 (permalink)
sprorchid's Avatar
sprorchid has at least 2000 rep pointssprorchid has at least 2000 rep pointssprorchid has at least 2000 rep pointssprorchid has at least 2000 rep pointssprorchid has at least 2000 rep pointssprorchid has at least 2000 rep pointssprorchid has at least 2000 rep pointssprorchid has at least 2000 rep pointssprorchid has at least 2000 rep pointssprorchid has at least 2000 rep pointssprorchid has at least 2000 rep points
There isn't a preferred battery for your bike, if you are talking brands. There are preferred brands on this forum, as you can see. Invest in a battery tender, and considering your bike, you probably aren't super worried about excess weight, so you'll probably go with a standard battery. you can pick up a battery at cyclegear or shop around online. you can either match up the CCA from your current battery or just look it up online.
your battery might still be ok, you need to test the voltage. any pepboys or autozone will do it for free. if it's below 12v toss it (recycle).
I personally prefer lithium, but I'm into weight savings and a longer lasting battery. It holds the charge longer also.
welcome to the forum, and safe riding to you.
sprorchid is offline   Reply With Quote
Old 12-08-2012, 03:27 PM   #8 (permalink)
Ya I just want a battery that will last a while. I dont really need to save weight my bikes already pretty heavy haha. Ill have to look into everything you posted for winterizing it. Thanks alot.
Old 12-08-2012, 04:30 PM   #9 (permalink)
BP
BP's Avatar
Yuasa
2005 Raw Ti ZX6R
BP is offline   Reply With Quote
Old 12-08-2012, 05:17 PM   #10 (permalink)
Jeff in Kentucky's Avatar
Cycle Gear sells a battery with a lifetime warranty, if you are close to one of their stores.
I have tried Advance and Auto Zone batteries, but they failed sooner for me than the Walmart Everstart.
