Need Suggestions : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Old 12-07-2012, 09:04 PM   #1 (permalink)
anthon008's Avatar
anthon008 has at least 10 rep points
Default Need Suggestions
As the title says i need suggestions or ideas, I have a ex650a that has bent forks and other issues what I want to do it take the motor and other parts and swap it into another bike or atv etc. Any ideas that will help, does any one know if the motor will fit in a zx6r frame?
2004 Ninja 250r- STOCK
anthon008 is offline   Reply With Quote
Old 12-07-2012, 09:07 PM   #2 (permalink)
TJ Beavers
goingtoscotland's Avatar
How many threads do we need?
Anything will fit with enough work. More work than it's worth.
Old 12-07-2012, 10:04 PM   #3 (permalink)
Sev
The Indifference Engine
Sev's Avatar
Won't fit in a zx6r frame without too much work. 2003/04 zx6r forks bolt up if you change the triple clamps as well.
Old 12-08-2012, 11:27 AM   #4 (permalink)
GaryIII has at least 10 rep points
Have you seen people put them on go cart frames? Look on Youtube at the r1 go carts. That may be a little too much though....
GaryIII is offline   Reply With Quote
Old 12-08-2012, 08:23 PM   #5 (permalink)
purposeinlife_1's Avatar
purposeinlife_1 has at least 2000 rep pointspurposeinlife_1 has at least 2000 rep pointspurposeinlife_1 has at least 2000 rep pointspurposeinlife_1 has at least 2000 rep pointspurposeinlife_1 has at least 2000 rep pointspurposeinlife_1 has at least 2000 rep pointspurposeinlife_1 has at least 2000 rep pointspurposeinlife_1 has at least 2000 rep pointspurposeinlife_1 has at least 2000 rep pointspurposeinlife_1 has at least 2000 rep pointspurposeinlife_1 has at least 2000 rep points
If you have to ask if you how to do it, there is a good chance you don't have the fab skills to make it work.
04 Acura TL. Total grandma car.
06 Frontier Nismo. Meh, it's ok.
06 636. Just sits in the garage keeping everyone else company.
06 Pitster Pro GPX 125. It's planing on killing me.
07 GSXR750 Trackbike
purposeinlife_1 is offline   Reply With Quote
Old 12-10-2012, 09:23 AM   #6 (permalink)
anthon008's Avatar
I am asking because i want to know what people had sucess with, I have a totaled bike due to forks, it is un usable. there are frames from zx6rs that are cheap. ex650r motor+ zx6r frame=minor project. I am not trying to invent thousands just looking to see what i can do with all these parts, because people are not really buying them. Thanks for the help garyIII and sev
Old 12-10-2012, 10:26 AM   #7 (permalink)
Best option is just to replace the forks. It's cheapest and least work.
If you want something different, fit a front end (yolks, wheel, forks and brakes) from a 636.
650 motor and zx6r frame isn't a minor project. Apart from very different engine mounts you'd have to offset the motor to line up the sprockets.
People aren't buying your parts because most of them also have wrecked forks and fairings with good motors as a result of buying bikes that they can't control as well as they thought they could.
Old 12-10-2012, 04:04 PM   #8 (permalink)
anthon008's Avatar
I see, it seems like i am gonna just look for a bad engine ex650 figure something else interesting out
Old 12-11-2012, 05:33 AM   #9 (permalink)
What about using the motor for a microlight?
No traffic or things to hit with one of those.
Old 12-11-2012, 07:16 AM   #10 (permalink)
Ianshort09's Avatar
Ianshort09 has at least 1000 rep pointsIanshort09 has at least 1000 rep pointsIanshort09 has at least 1000 rep pointsIanshort09 has at least 1000 rep pointsIanshort09 has at least 1000 rep pointsIanshort09 has at least 1000 rep pointsIanshort09 has at least 1000 rep pointsIanshort09 has at least 1000 rep pointsIanshort09 has at least 1000 rep points
Umm.... It's a forum... Forums have threads... Some of them even have a few repeat threads...
Nature
Of
The
Beast
Back on topic
I agree with just replace the forks and whatever else is broken/bent etc... Finding the same bike with a bad motor isn't a bad thought either
A 650cc go cart would be sweet but I've heard I those v-twins can really tear up welded joints with the vibrations they cause... But I'm sure with heavy enough mounts/ welds etc it would work.
I would fix it/find a donor bike and come up with a different "project". Start small and cheap, learn to weld/fabricate in the process maybe?? If it works... Great... If it doesn't... You will still have a bike and may not have burnt up as much money.
Ianshort09 is offline   Reply With Quote
