Talk to me about grips for track use - Page 3 : KawiForums.com Kawasaki Forums: Kawasaki motorcycle forums
Old 12-18-2012, 09:12 AM   #21 (permalink)
exalted512's Avatar
CMRA doesn't require it.
-Cody
2009 650R (Street)--Stock
exalted512 is online now   Reply With Quote
Old 12-19-2012, 10:46 AM   #22 (permalink)
sprorchid's Avatar
sprorchid has at least 2000 rep pointssprorchid has at least 2000 rep pointssprorchid has at least 2000 rep pointssprorchid has at least 2000 rep pointssprorchid has at least 2000 rep pointssprorchid has at least 2000 rep pointssprorchid has at least 2000 rep pointssprorchid has at least 2000 rep pointssprorchid has at least 2000 rep pointssprorchid has at least 2000 rep pointssprorchid has at least 2000 rep points
For those of you who track, what do you safety wire?
sprorchid is offline   Reply With Quote
Old 12-19-2012, 11:03 AM   #23 (permalink)
exalted512's Avatar
When I just did track, I safety wired the oil drain plug and filter. I safety wired a clip on the oil fill and rear axle.
For racing:
front axle
pinch bolts
front / rear caliper bolts
silicon on the oil galley plugs
radiator cap
coolant drain
-Cody
Old 12-19-2012, 11:05 AM   #24 (permalink)
exalted512's Avatar
I also drilled a hole in the bolt on my exhaust from the exhaust hanger and put safety wire in it. It's not deigned to keep the nut completely tight, just designed to ensure it would not completely come off the exhaust hanger.
-Cody
Old 12-19-2012, 02:04 PM   #25 (permalink)
J_Fuggin_T's Avatar
Location: Northwest, Indiana 2009 Kawi ZX6r (track only)
J_Fuggin_T has between 30,000 and 40,000 rep pointsJ_Fuggin_T has between 30,000 and 40,000 rep pointsJ_Fuggin_T has between 30,000 and 40,000 rep pointsJ_Fuggin_T has between 30,000 and 40,000 rep pointsJ_Fuggin_T has between 30,000 and 40,000 rep pointsJ_Fuggin_T has between 30,000 and 40,000 rep pointsJ_Fuggin_T has between 30,000 and 40,000 rep pointsJ_Fuggin_T has between 30,000 and 40,000 rep pointsJ_Fuggin_T has between 30,000 and 40,000 rep pointsJ_Fuggin_T has between 30,000 and 40,000 rep pointsJ_Fuggin_T has between 30,000 and 40,000 rep points
As little as possible. If you torque them they don't come loose. I do the oil, filler, plug & filter.
Mod list: Ohlins 30mm frnt cartrige kit / JRi piggyback triple shock / Brembo RCS / galfer superbike lines / pf 07 pads / Leo Vince sbk corsa Ti full exhaust / Stock revalved ohlins damper / Armor Bodies / Servobuddy / Skutr.net captive spacers / Vortex Rearsets / Bazzaz FI/QS/TC / Motion pro revolver / XT gpx / kit clutch mod /
J_Fuggin_T is offline   Reply With Quote
Old 12-19-2012, 02:59 PM   #26 (permalink)
The Antistart
Green's Avatar
On my bike, and I only did track days, I safety wired:
Master banjos
Caliper banjos
Caliper mounts
Pinch bolts
Rear axle hair pin
Oil plug
Oil filter
Oil filler cap
Grips
Dzus fasteners
Exhaust springs (not on the head, but the rest of them)
Coolant drain plugs
Radiator cap
The holes cost nothing to drill (if you don't break the bit), and safety wire is cheap insurance.
Old 12-19-2012, 03:12 PM   #27 (permalink)
BossLadyRR's Avatar
BossLadyRR has at least 500 rep pointsBossLadyRR has at least 500 rep pointsBossLadyRR has at least 500 rep pointsBossLadyRR has at least 500 rep pointsBossLadyRR has at least 500 rep pointsBossLadyRR has at least 500 rep pointsBossLadyRR has at least 500 rep pointsBossLadyRR has at least 500 rep points
+1 on the thin renthols. I had to be talked into the thinner ones but I wouldn't ride with anything else now
BossLadyRR is offline   Reply With Quote
Old 12-19-2012, 11:42 PM   #28 (permalink)
purposeinlife_1's Avatar
purposeinlife_1 has at least 2000 rep pointspurposeinlife_1 has at least 2000 rep pointspurposeinlife_1 has at least 2000 rep pointspurposeinlife_1 has at least 2000 rep pointspurposeinlife_1 has at least 2000 rep pointspurposeinlife_1 has at least 2000 rep pointspurposeinlife_1 has at least 2000 rep pointspurposeinlife_1 has at least 2000 rep pointspurposeinlife_1 has at least 2000 rep pointspurposeinlife_1 has at least 2000 rep pointspurposeinlife_1 has at least 2000 rep points
I really like my Renthal's.
04 Acura TL. Total grandma car.
06 Frontier Nismo. Meh, it's ok.
06 636. Just sits in the garage keeping everyone else company.
06 Pitster Pro GPX 125. It's planing on killing me.
07 GSXR750 Trackbike
purposeinlife_1 is offline   Reply With Quote
Old 01-03-2013, 10:18 PM   #29 (permalink)
venomousr1993's Avatar
venomousr1993 has at least 50 rep pointsvenomousr1993 has at least 50 rep pointsvenomousr1993 has at least 50 rep points
x2
venomousr1993 is offline   Reply With Quote
Old 01-04-2013, 12:29 AM   #30 (permalink)
sprorchid's Avatar
Thanks guys, for all the recs, very helpful.
