Hi all,
I have a leak on my ER6, I have noticed this only recently. It doesn't always leak which is strange. I took the bike out today and after 10 miles there was a small amount of oil, I cleaned it and by the time I rode home no sign of any leak.
Any way need advice to get it sorted. I believe that this is from the "timing rotor cap" on the clutch casing?
Why would there be oil leaking from here, does oil sit just behind this cover?
Is this a sign of issues with my valve clearance or timing?
I am hoping there is an o ring seal behind the cap and this could be the issue? Or should there not be oil at all from behind the cap?
I have tired but can't get the cap off.
Thanks
Thanks
